Question about Garden
2 year old bolens premium snowblower won't start. Never used.
Got the machine about two years ago brand new. Started at that itme. but no snow, so did not use for 2 winters. Sat in garage, now trying to start and it would not. Put fuel stabilizer last summer but did not try to start it at that time. did the spark plug test and look good. Primer does not seem to be spraying fuel. Just heaing sound of air and not smelling any fuel when prmer is pressed 4 to 6 times..
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Posted on Jan 19, 2009
SOURCE: Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Posted on May 27, 2009
SOURCE: Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
Posted on Nov 28, 2009
SOURCE: Lawn Tractor won't start Craftsman LT1000 17.5 OHV
you carburator just needs to be cleaned/adjusted, and if your original fuel filter isnt clogged and looks clean, leave it, but the air filter is a good idea to change at least once a year (grass shavings covered filters dont help the engine much).
Posted on Feb 20, 2010
  • 634 Answers
SOURCE: J.D.x300 tractor 8 months old will not start. It
ok a couple of things to try 1 try using starter fluid in carburetor 2 second spritz and crank does it fire or pop? if yes then there is spark, if not then pull spark plug and put new one and try again, if no then leave spark plug out of engine and lay on engine with wire connected and look for spark( do in shade to see better. if no spark then coil if bad. if it does fire on starter fluid, check gas filter and air cleaner it may be too lean or rich to fire properly.
Posted on Apr 23, 2010
I started this snowblower in the summer and it worked fine...both winters I've tried to use it it won't start. The first year I had it it worked very well.
So you are saying it wont run in the cold. Will it run if you left it in the house until you wanted to use it?
Are you going thru the procedure of Choking the engine ? Is there a Primer Bulb that you have to push on this machine?
I'm just saying that engines don't like the cold to begin with, just make sure you are going thru the 'Cold Start' procedure properly.
Jan 20, 2016 | Toro Power Clear Snowblower 418ZR - 38272
Snowblower won't start this year. Machine
Did you run the engine for about 15 minutes after you added the fuel conditioner? If not then the conditioner didn't get into the carburetor and you probably will need to take it apart and clean it again. The ethanol in today's fuel causes problems in carbs that sit
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 20, 2013 | Garden
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Tecumseh 8hp snow blower. Hi started the snowblower this year for the first time with no problems. The oil was changed and the level was fine. I cleared the driveway and after about an hour turned it
not sure i understand you correctly but if it turns over to a spot and stops. it is on the compression stroke. that means the valves are out of adjustment. reset the valve clearances and it should be as good as new. or take the spark plug out and see if when you try to start it it shoots out gas out the exhaust that means you have a bad needle or seat in the carburetor. it will need to have a kit put in it. it is easy to do and cheap.
Sep 01, 2017 | Yard Machines Garden
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Truck just won't start. Light and everything else has power. Won't crank at all. Anti Theft system was not set and hasn't been used in almost a year. Had this problem a year ago but it
What year?? What I have run into is the Anti Theft cable shorts out causing the intermittent starting issue. I would try removing the cable
Oct 01, 2012 | Cars & Trucks
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
