How to clean the filter of a tornado gold air-conditioner?
I do not know,how and where to sort the Filter to clean it
5 Suggested Answers
  • 105 Answers
SOURCE: air conditioner freezing up
Your unit is low on freon. Take the unit to a service facility & have it recharged & the leak repaired. Note that ice formation may normal if the outside temperature is below 45-50F. If you must use it in the meantime, leaving the unit on fan only will melt the ice much faster.
Posted on Jul 17, 2007
SOURCE: Maytag Air Conditioner NMPEB08F2A
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Posted on Aug 16, 2007
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Posted on Oct 07, 2008
How do you clean the coils?
Good Morning Friend,
I understand you want o know how to remove the coils to clean them on your Frigidaire air conditioner, model# FAS257S2A. You will not be removing the coils. If you will please start by cleaning the filter like so:
• Tilt the panel out by grasping the panel from both sides, just below the controls and the air directional louvers, and gently pull to release. Pivot the panel on its hinge's and remove the filter.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
While you are cleaning the filter, the coils will be located behind the filter area, you can clean them with a vacuum extension. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FAS257S2A WallWindow Air...
How often should I clean my air conditioner filter?
You should clean your air conditioner filter at least 2-3 times per month. For a complete guide of how to clean an air conditioner filter, check out this website: http://www.ehow.com/how_5105292_clean-air-conditioner-filters.html
Feb 07, 2013 | Filter Heating & Cooling
You should clean your air conditioner filter at least 2-3times per month. For a complete guide of how to clean an air conditionerfilter, check out this website: http://www.ehow.com/how_5105292_clean-air-conditioner-filters.html
Jul 15, 2012 | Heating & Cooling
READS E1
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier HWR08XC7 Air Conditioner
E1 error code
Aug 07, 2011 | Haier HWR06XC7 Air Conditioner
I was just wondering how to clean the filter on my Maytag window air conditioner. I saw somewhere that they need to be cleaned and don't know how to take the filter out to clean it, or exactly where...
M's Kitty . I can't help you with the remote But I might be aboe to help you with the filter service.
If you look behind the front cover you can see the coils with a spong type filter infront of it. You might have to remove the whole cover to get to it and sometimes there is a door of sorts to allow access. shut the unit down and remove the filter and wash it out with warm soapy water and replace it. and restart the unit. and your off and running again.. You should check your filter at least bi weekly unil you see that remains clean and you might get by with a monthly inspection .. Hope this helps .. Let me know have a good day .. Jon
Aug 01, 2011 | Heating & Cooling
Turning off code e1 flashing what is e1 code
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
"Check Filter" light is on
Take out the filter and pour water on the oposite side that is the dirt,if the water is not enough use degreaser and also clean thefront cover where the filter goes.
Apr 04, 2009 | Maytag M6Q10F2A Air Conditioner
The screen is flashing E1
I was told the filter needs to be cleaned.
Turn the air conditioner OFF and unplug it.The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. After cleaning, replace the filter and plug the air conditioner back in.
Hope this helps :)
Aug 07, 2008 | Danby Heating & Cooling
Gold star model: LW-G0710CL
buy a new filter ensure your filter is clean as it can be replace it make sure the coil on the out side is clean as well
Jun 14, 2008 | Goldstar Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
