Question about Frigidaire ATF6000ES Front Load Washer
Washer won't spin at high speed....makes loud clunking noises
My drum now wobbles and the washer makes huge noises when it is washing. I bought it in 2004 because of the stacking feature to save space.
  • gregors29 Jan 22, 2009
    Thank you!
  • rawhide19 Jan 22, 2009
    Hello
    My front loader is making a loud noice when it spinns. Is there a bearing and How easy is it ti replace. Thank you
    Novelist:
  • 101 Answers
You probably have a broken shock on your washer. The front loaders have two shocks on them to stabilize the drum when it spins. Over loading the machine will cause these to break. Luckily they aren't too much to replace, only around 30 dollars each. They are quite a pain though to change out. When you remove the back panel of the washer you will see the shocks. Most likely you have one broke, maybe both though. Don't use it though until you get them changed out. It will just do more damage to the washer. If you have any other questions let me know and let me know if this was helpful to you. Good luck and I am glad that I could help you.
Posted on Jan 22, 2009
My Duet Washer is making loud noise during spin cycle and has plastic shavings, from front tub rubbing i assume.
Hi, it could be your drum bearings are gone the drum would wobble slightly. A way of checking is , machine unplugged put one hand at bottom front and one hand at top front edge and push up and down if it clunks quite badly then your bearings on the drum shaft are needing renewed. You also have a shock absorber for steading the drum this can also fail. The absorber is very hard to compress so if its easy to compress then it needs re-newed.
Dec 29, 2015 | Washing Machines
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Mar 10, 2011 | Kenmore HE3T Washer
I have just bought a Whirlpool 6th sense 8kg load washer. It makes a clunking noise whilst washing and seems to be loud when spinning is this normal
have you been overloading the drum---thiscan put too much strain on the rear bearings---you willhave to replace the complete drum
Dec 07, 2010 | Whirlpool AWM6100 Front Load Washer
I purchased the Frigidaire stackable front loading washer/dryer pair in 2004. A friend also has the same model and so did my sister. My sister said there was a loud clunk one day and the washer stopped...
Your power supply has failed, need part # 134409904, check ebay, about $70
this board is in a white plastic box with wires running to the motor, access from the back of the machine, maybe say magnetek on it 4246-99-1
Jan 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
151 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
