Question about Holmes Products HM4600-U 11 Gallon Humidifier
Holmes HM4600 Humidifier LEAKING - - HELP
Just purchased this and is leaking water everywhere!! Placed it in a plastic tray and is still leaking around 3 to 4 cups of water. Appears to happen when it switches tanks (one drains, then the other kicks in?). Have checked for cracks, etc to no avail. Any ideas? We have to keep sopping the water out of the tray around it every 4 to 6 hours.
    Novelist:
  • 88 Answers
Well since you just purchased this item, you should be able to return it for exchange, and it should still be under warranty, but if thats not doable, then it sounds to me like its a O-ring that is bad if the tanks are removable, best bet though is to exchange it, look at your home owners paperwork, to see about the warranty, more than likely your covered, hope that helped,
mr.grzz
Posted on Jan 22, 2009
Humidifier wont stop leaking water at bottom
Hard water will build up on the rubber plunger casket and the beveled edge were the plunger seats in the cap, if you clean both pieces it will seat it self again
Apr 13, 2014 | Holmes Products Warm Mist HM5700...
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Have been looking for just one of the tanks as the rubber stopper rotted away. Do you know where I could just buy one tank?
you check at local hardware stores. or if your in canada check with canadian tire. if nobody has it locally. you might have to call the manufacturer to order it directly from them.
Aug 17, 2009 | Holmes Products HM4600-U 11 Gallon...
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Need Manual for Holmes Humidifier HM4600
because no one else posted the site, heres the pdf
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
Dec 21, 2008 | Holmes Products HM4600-U 11 Gallon...
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Waters tanks never empty
Either you have no wick/filters or they are installed incorrectly. Tanks should empty within hours.
Mar 01, 2008 | Holmes Products HM4600-U 11 Gallon...
Holmes Products HM4600-U 11 Gallon Humidifier Logo
377 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
ray gallant
Ben Eng
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
