Question about Nautilus T514 Treadmill
I have a T514 treadmill that stops dead after @ 10min. of use. I have already lubed the track, do you have any other solutions
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: my tv pixelates when i am running on the
Their is either a cold soldier joints or loose connections on the upper console you'll have to physically inspect all connections leading from the lower board to upper console. Usually the display screen are connected with a mylar connector or hard wired to upper console if your not a tech and don't have any electronics background this can get very involved. My suggestions is call Nautilus and if still under warranty replace unit, if not under warranty get pricing or take it to a computer shop a skilled tech should be able to diagnose a locate the problem.
Posted on May 29, 2010
Daniel S
  • 4323 Answers
SOURCE: Our Nautilus T514 treadmill stops
Hi
Try clearing the error by unplugging the treadmil. if it doesn't clear then try and press stop button for 10 seconds. Insure cable is connected securely to Console. All wires in cable should be intact. If any are cut or crimped, replace cable. If error doesn't go then lubricate the treadmill as given in this manual---
Nautilus Treadmill 514 Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 04, 2010
ercupa190
  • 12223 Answers
SOURCE: nautilus t514 safe key issue
1_ reset the machine, disconnect the machine.
2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet.
3) replace and go and buy in homedepot for little price!
God bless you
Posted on Jul 18, 2012
How can I fix my treadmill as it won't run due to Safety Key Lock even when Safety Key is inserted?
Check here for guidance on how replace or repair your safety key:
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-safety-key/
http://www.treadmillsrepair.co.uk/2014/08/treadmill-safety-key.html
Apr 03, 2014 | Nautilus T514 Treadmill
My a2350 treadmill just stopped working - console and motor stopped
plealse LUBE the deck belt + rollers bearing too . you must do it after 150 miles aprox.
2) adjust the REED switch see the diagram, clean it, test for open or faulty. Tight the connector very well.
Jan 25, 2013 | Nordic Track NordicTrack A2350 Pro...
Contiually beeping, when started it stops a few seconds later
LUBE the deck belt+ roller bearing too. see the video and proceed according. If the problem persist after you lube , time to change the deck belt board complete.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack T7 si Treadmill
Treadmill belt stops abruptly
This happen because the lack of LUBE in the machine according with the instruction maintenance.
Please see the video and proceed according , LUBE the rollers bearing too.
God bless you
Jan 07, 2013 | Nordic Track Nordictrack A2350 Treadmill...
Nautilus t514 safe key issue
God bless you
Jul 18, 2012 | Nautilus T514 Treadmill
Treadmill belt stops or bogs down
1= Lube the deck belt, this problem come because the deck is worn, and produce enough friction and cause shut down, for protection to the electronic system
2= lube the rollers bearing.
3= Run the software calibration INmediately, for diagnose and troubleshooting.
4= Test the input motor voltage, see my personal TIPS for test motor
5= tESt the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block attached.
God bless you
Jul 07, 2012 | Nordic Track NordicTrack T5 zi Treadmill
Nordictrack c1800 goes into cool down mode at the start and then stops
Lube the treadmills deck belt inmediately
2= lube the rollers bearing too
3=measure the input voltage motor, if there are the motor need repair
4) measure the output board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jul 03, 2012 | Nordic Track Exercise & Fitness
My treadmill stops after run for awhile ,why is this happening?
1)Lube the deck belt,this is happening because the lack of lube produce enough friction between deck vs deck belt, and result in shut down.
2)lube The rollers bearing very well
3)measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are Not the board is faulty. see the bloc diagram
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
Belt on Nordic Track T4.0 treadmill stops
Dear Sir:
1) Lube the treadmill in according with the instruction manual.
2) The reason is lack of lube by maintenance, that produce enough friction with shut down for to protect electronic system.
3) Test the deck belt if is worn, and replace it.
4) Test the rollers bearings
5) See the bearing motor
6) Test the input voltage motor coming from the output from the main motor board,, use DVOM.
7) See my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Nordic Track Exercise & Fitness
Treadmill slows down and stops
hi..probably the reason to this problem may be due to
worn belt and deck or a belt that needs lube.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | TEKK Fitness Two Treadmill
Nautilus T514 Treadmill Logo
15 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
