Question about Car Audio & Video
My sub in my car keeps beating with the volume down and not to the beat
It keeps a constant thumping and not to the music !
  • 14 Answers
SOURCE: Car sub not working
has your amp been accidently swiched to stereo instead of mono,if so,swich it back.
Posted on Feb 17, 2007
  • 98 Answers
SOURCE: my subwoofers have a heart beat to them
Ok.... FIRST COMMON PROBLEM: recheck your ground connection. Make sure that your amps ground wire is securely bolted to the metal body of your car. Not only that- yo uhave to scrape or use sandpapar to make sure that the terminal is touching bare metal.. this is a very common problem. Nobody realizes that the ground connection is just as impoarant as the power connection... Next unplug youir rca cables from the amp. If the heartbeating goes away then mabye you have a rca cable or deck issue. If you can wiggle the rcas at the amp and make it heartbeat more or less.. then perhaps the rca terminals have come unsoldered form the circuit board... in any case without me looking at it personally this is about all i can tell you. CHeck your connections and GOOD LUCK!!!!!
Posted on Aug 27, 2007
  • 92 Answers
SOURCE: the car sub I have still beats with no music and makes sounds
Probably that ground, seat bolts are bad 'cause they rust, seat belts are even worse 'cause they have some sort of coating on them to keep them tight but it screws up their grounding characteristics.
Find a good solid metal place to ground to as well.
Also, make sure the head unit is grounded well and if all else fails, try a new patch cord from the head unit to the amp. Process of elimination is needed to solve these problems.
Posted on Oct 06, 2008
SOURCE: sub woofer is blowing up and down even when head unit is off
Posted on Jun 11, 2009
  • 81 Answers
SOURCE: i just moved my 12
It sounds like you have a feedback problem between your amp and your speakers this is usually caused by a bad or weak ground between the amp and chassis ground and speakers and chassis groung, also make sure that the correct post on the speakers is the one attached to ground as this makes a big differance especially with high power systems. Hope This Helps Don
Posted on Dec 02, 2009
Amplifier in protection
That thump beat was called motor boating and is amplfier oscillation. It means that a driving transistor in the audio output circuit is bad. You will have to send this in.
Apr 21, 2014 | Car Audio & Video
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
A2200 htc wont bump my subs and the fans never turn off
check your wiring's, there are two positive lines, one is directly connected to the batteries positive terminal and the remote positive is connected to the ignition's positive, and make sure it is properly grounded.
Jun 10, 2010 | AudioBahn A2300HCT Car Audio Amplifier
My subs don't bump to the beat, they just go THUMP THUMP THUMP...
It sounds like you need to ask for pro help mate, mybe the amp just needs setting properly, Is the amp on bypass for bass, or does the amp run the complete system
Jun 13, 2009 | Cadence TXA 750D High Power Mono Amplifier...
Sub woofer is blowing up and down even when head unit is off
This is an internal power supply failure - most likely a failed capacitor or bad ground trace..
Your amplifier requires repair.
To verify this - remove the RCA cables and if the "heartbeat" is still present - take the amplifier to a local repair shop that specializes in car audio and tell them your symptoms.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Sony XS-L121P5 Car Subwoofer
Constant pounding of subwoofer
Have you tried another pair of RCA's? Sounds like you have a bad pair of them.
Feb 07, 2009 | MTX RT2200 Car Audio Amplifier
My i.Beat emo will not charge
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 12, 2008 | Trekstor Beat censo 73812 MP3 Player
12" kicker l7
It sounds like the "flex" surrounding your SUB has not been flexed properly. When it comes to SUBS, if you can't fix it in the 1st hr. Its better to replace em.
Try pushing on your SUB repeatedly for about 3-5mins. Working the "flex" on it. If there still is not give in it, time to replace.
Feb 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
