Question about Seagate Momentus XT hybrid hard drive - 750 GB - SATA-600
Jumper for Seagate Momentus XT 750 GB
What jumper size is compatible with Momentus XT 750 GB
shadow5599
  • 51 Answers
SOURCE: Seagate momentus 3 60gb problem
What software did you use for the cloning?
Ghost is the preferred method.
Be sure to choose a disk to disk clone, not a partition clone.
It sounds like you may have created a 20G partition and left 40G unallocated.
Partition Magic may also take care of the problem, if you have access to a copy.
Posted on Oct 16, 2007
  • 9 Answers
SOURCE: Seagate Momentus 4200.2 120GB
Some laptop manufacturers use the 4 pins to the side of the data connection to force Master / Slave. Do you have a jumper shorting 2 of these pins? If so, remove the jumper and try it again in your external caddy. Had this problem 2 weeks ago with a Toshiba notebook having the Blue Screen of Death. Removed the jumper and then the disk worked perfectly!! Strange but True.
Cheers
Tim
Posted on Dec 13, 2007
  • 979 Answers
SOURCE: Seagate Free Agent DeskTop 750 gb stopped working
Good day maam, hi, sorry to say this but, you lost your hard drive already. You lost your Files to. There are slim chances you need to pay for HArd drive recovery, this are offered by some private company check out this website: http://www.harddriverecovery.org/
Posted on Dec 17, 2009
igor106
  • 277 Answers
SOURCE: I have a seagate momentus
see if the BIOS setting for the hard drive is se to IDE. Then, see if there are any jumpers on the hard drive. There should be a diagram on the drive itself that you can follow to place the jumper as Master, or just remove the jumper.
Also, you may want to test the hard drive for surface problems before you make it a system drive. Usually system hard drives go through thousands of read/write cycles that wears them down quite fast, so if the hard drive works just fine as an external USB drive that doesnt mean it will do good as system drive.
Posted on Dec 21, 2010
  • 2386 Answers
SOURCE: which is the correct jumper settings on Seagate
Hello Please see the image below for correct jumper setting cmptrlink_16.jpg
Hope this helps, if so do rate the solution
Posted on Jan 15, 2011
Seagate momentus 5400.6 drivers download
if it is broken thenit will not take drivers anyway .
Apr 21, 2013 | Seagate Momentus 5400.6 (ST9250315AS) 250...
May i upgrade my notebook
1) Intel T7700 [ 2.4GHz, and 800MHz FSB ]
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Merom.22.2C_.22Merom-2M.22_.28standard-voltage.2C_65_nm.29
2) 4GB of DDR2 Sdram (SO-DIMM) that is 667MegaHertz.
(PC2-5300)
3) Seagate Momentus XT 500GB harddrive
Graphics upgrade? No.
Regards,
joecoolvette
Sep 17, 2012 | Acer Extensa 5620-4020 Notebook
I am interested in this drive Seagate Momentus XT 500 GB. I want to know how to install this drive into my desk top computer with a 3.0 slot for the drive as it is only 2.5 inches wide.
To install a Hard Disk Drive(HDD) into your desktop, take off the side panel of your case. Locate the SATA slots on it, they should be above the available Optical drive slots.
Put it in place, depending on your case you should either have a latch which locks it in place or you will have screws. After you've done, make sure that if you have another HDD in your PC, and you will not use this HDD for System files(C:\ drive), you will have to set the new one to Slave configuration. To do this you need to take out that jumper inside of the HDD(you can use some tweezers) and, according to what's printed on your HDD, move it up or down.
When you've done that, insert the SATA power supply cables from your Power Supply(PSU). After that use the SATA interface cables which came with your HDD and plug them into your Motherboard's SATA adapters. Locations of these vary depending on the motherboard so it's always best to refer to your Motherboard's manual to check locations.
After that start your PC and open up your BIOS/CMOS. Usually you press a key such as F2/F5/Esc on bootup. Configure your Motherboard to check for new drivers. After that save and exit and it will restart your PC. You should have installed your new HDD!
Aug 20, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
I have a seagate momentus st94q19a 40 gb hard drive from an old netbook. When I try to install Windows XP, it tells me it can't access the hard drive. Is there any way to fix this or is this hard drive...
Dec 21, 2010 | Seagate Computers & Internet
Hi There. I am looking for an Internal Hard Drive to suit a Dell Inspiron 1525 Laptop. Seagate Momentus 5400.3 160Gb ST9160821AS. Where can I get one or is there another Hard Drive that would be OK to use...
I suggest you check the specification of your Dell laptop to see the maximum size hard drive it can support. The maximum size hard disk you can install in the laptop depends upon the BIOS.
Any major brand of 2 1/2" hard drive will work with the Dell.
Oct 27, 2010 | Seagate Momentus 5400.3 - 40GB - 5400rpm -...
Seagate Momentus XT hybrid hard drive - 750 GB - SATA-600 Logo
65 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
