Question about Dishwashers
Defy Dishmaid DW12 stopped mid cycle and does not respond I checked for any moisture underneath the machine by opening the back and side panels. the only response that I do see is when the door is open the light burns but when it's closed, it is dead. By turning the program/ cycle knob nothing happens.
  • gary233 Apr 19, 2009
    My Defy dishmaid 3 programme worked for a short period and then just stopped. When I open the door there is water on the tray that is not draining. does the machine have to be plumbed into hot water or is cold water okey
Exact same peoblem. Did you guys have any luck?
Posted on Jan 11, 2010
  • ILANSA May 30, 2011
    oh please tell me you got an answer for this. Same thing happened to me yesterday. It stopped mid-cycle and now does not work at all. The power light doesnt even come on.
    We had this once before - but the technicians opened something and drained water and it worked fine - but for the life of me i dont know what they did.
Tip
So your Dishwasher sits and "Humming" cannot turn off, no response.
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
on Mar 27, 2010 | Dishwashers
Defy dishmaid DW12
You have a major short to ground which is tripping the breaker. Get an electrician to check the machine, it may be as simple as you have trapped the cable. Don\'t mess with water and electrics. Electricity is the silent killer.
Aug 21, 2014 | KitchenAid Kitchen Aid Diswasher Part...
I have a Hotpoint WML540 Aquarius which has stopped mid cycle, all the lights are flashing and it is stuck on 'pump out' can anyone please advise how to fix this?
Switch off the machine for sometime and then power it while holding the play/pause button. If the machine does not reset but continues to flash it is possible that there are errors within or is a failure of the panel. Check the door switch, check the connectors and finally check for moisture in panel- If so use a hair dryer to mop up the moisture by heating the panel slowly,
Jan 14, 2013 | Washing Machines
Hi. My dishmaid dw12 sometimes leakes water. ive checked the water inlet and draing and its not that. what could it be
If the water is appearing at the front of the dishwasher during use, it's most likely that one of the door seals needs replacing.
There is a white panel, about 4 inches high, below the door. Stand to the side of the washer, open the door about half-way, and have a feel about on top of that lower panel. If it's wet, it's almost certain one of the seals is perished - usually the bottom door seal. This seal isn't visible like the goal-post seal that runs around the sides and top.
Also, food waste can build up on or under the seals and cause leaks.
If the water is appearing from the back or under the washer, then further investigation is needed and you may need an enginner. It's hard to be definite as you haven't been very specific about where and when the leak occurs.
Oct 18, 2010 | Dishwashers
It has the green light lflashing where it start but nothing happens
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Jun 01, 2010 | Dishwashers
Opened lid during wash cycle. Machine stopped but later restarted. The same thing happened two weeks later, but the touchpad has no function. It is getting electrical power to the dishwasher. Thoughts?
May 06, 2010 | Dishwashers
Not draining, pump clicking
Apr 08, 2010 | Dishwashers
No water enters the inside of the dishwasher and the motor makes a sound as if under strain. It was working perfectly and then sudenly started leaking from underneath. Could not locate the leak yet. Old...
it is leaking from the seal above the motor in the centre bottom of your machine also check the door seal they tend to leak on older machines as well
Dec 14, 2009 | Dishwashers
Dishwashers Logo
1,459 people viewed this question
Top Dishwashers Experts
