Question about Dishwashers
Dish washer wont drain all the way model gdwf100v40ww
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: dish washer wont drain
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 25, 2010
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Dishes and glassware are filmy after the cycle. There is salt in the washer.
Probably not draining properly so wont rinse.Put end of drain hose into bucket to check,you should get a good flow.
Mar 07, 2015 | Thermador Dishwashers
Dish washer wont empty out leaves about 2 or 3 in in it
Drain hose clogged or Not ran in the proper draining position, under the sink where the hose ties into the drain system or garbage disposal, the hose should be higher than the connection point, I have fixed this by tie strapping hose to the bottom of the counter or sink, hope that helps ?
Feb 27, 2015 | Kenmore Dishwashers
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
Does not pump water. Leaves dishes soappy
We really need your model number to help you properly. In the mean time you can check you sink connection and air gap for obstructions. Usually the cover just pulls up and off then you unscrew the cap to expose the drain tube for the dishwasher. More often than not if the unit fills and washes but leave soap on the dishes a clogged drain line is the problem. You may have to run something down the drain tube to clear it. Usually you will see the obstruction when you remove the cap. There is a remote possibility if it drains into a garbage disposal that food particles have clogged the drain outlet inside the garbage disposal. Hope this resolves your problems. Cheers!
Sep 20, 2009 | GE 15" Laundry Pedestal for Horizontal...
Water wont drain after wash!! Dishes wont dry all the way also
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control board
Replace if defective (note: uncommon problem).
Jun 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher seems to be clogged, wont drain
I had the same problem and it was solve by checking the food disposal were the dish washer is usually attached for draining, if you resently replaced the disposal it could be that the drain hold was never openned. I hope this helps
Apr 22, 2009 | Dishwashers
Kenmore dish washer wont drain
Those are Chinese massage balls. You place them in your palm and rub them together and the result is a "calming" effect, which are ingeniously placed their by the courteous engineers at Kenmore to help you relax while you perform the self-repair. Just kidding. I had the same problem and learned that they are called "float balls". There should a small hole where the water comes up and drains - they are placed in that hole.
Nov 14, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
