Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
How to lock my belkin wireless router and i don't know how to get to settings
5 Suggested Answers
  • 67 Answers
SOURCE: Mac laptops can't access an open (no security set) Belkin Router
A "locked" wireless means the router is encrypting packets of information as it sends/receives. You would need to enter the 64-bit or 128-bit key which was created by the router when you configured the passphrase to use.
Posted on Mar 04, 2009
  • 19 Answers
SOURCE: need to lock my router
I'm not sure if this is the correct model, but the steps should be similiar. Please follow the link to the belkin website and follow their instructions:
Posted on Mar 15, 2009
  • 3289 Answers
SOURCE: I want to know if an ' N ' range wireless router s
All of the "N" routers I have seen are backward compatible to the 54 Mb "G" standard. An "N" router on your network will mot likely not work any better than the old "G" router did (unless there was something wrong with it) if you continue to use the old "G" card in the PC.
To take advantage of the greater range and other technical advances that the "N" router offers, an "N" card should used in the PC, too.
To maximize speed and reliability of any wireless "G" network, decrease as much a s possible, the distance between the "G" router and wireless PC.
An open air, "line of sight" path is best. A path through gypsum board, wood, foil backed insulation, brick, concrete, steel goes from "OK" to "very difficult". Basically, the thickness and type of material can affect the signal. The harder it is for you to drill through the material - so is the difficulty of passing a wireless signal through (more or less).
Minimize interference by reducing or removing any cordless 2.4 Ghz telephones, intercoms, etc. These devices *can* significantly reduce the range of wireless G networks. Try it yourself by unplugging the base and removing the battery from a handset to see if this is a source of interference for your location.
Posted on Sep 30, 2009
  • 1768 Answers
SOURCE: F5D7634 Belkin Router how do I disable wireless op...
1. log into the router and click the "wireless" and uncheck the radio brocast.
Posted on May 22, 2010
Wireless light flashes & can't connect
Are You Sure You Have Signal coming into modem/router sometimes the red light indicates no connection is it dsl or cable or? if DSL can you use the phone disconnect the filter. and plug the cord strait into the wall plug.cable could be the connection check for shorts could be an issue with your carrier call them for a simple electronic reset Hope this helps!
Jul 26, 2017 | Belkin Components F6D4230-4 Wireless...
I have lost the security code and have a new laptop, how do i set it up to work
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I have my wii all set up except for the internet. a guy came out & fixed my wireless but now its asking fr a password & i dont know what that would be... i thought maybe on the back of my router...
If it's a Linksys wireless router, then the default password is "admin" in small letters (no caps). Don't worry about the username, it won't require it, until you get into the settings. If it's a Belkin, then Google: Belkin default password, and it will then give you a list of default passwords, depending on your model type. Good luck.
Jul 05, 2011 | Computers & Internet
I have a new Canon MG5220 that I am trying to set up to my imac desktop and Belkin wireless router F6D4230-4v1. I need the SSID or network name and network key or WPA/WPA2 passphrase. I don't know...
That is on your router under wireless. You have to login to your router and look for wireless settings. the passphrase should be in there. The SSID is something that you should of made. That should also be under your wireless settings. It sounds like you have the SSID broadcasting turned off. Under the wireless settings turn it back on. Turning it off only gives you problems and it is a false security thinking that someone can't get on your network when it is turned off. In the event that you can't get on your router reset it by holding in the reset button on the back of the router for 5 secs then login with the default information.
Jun 23, 2011 | Belkin Basic Wireless Router
I can't find the CD to set up my wireless. Where
Go here and select the proper model for your router, then download the setup software and install.
May 31, 2011 | Belkin (F6D42304) Wireless Router
I need to reset this so i can lock it i suppose?
If there has been a password already set that you don't know you will need to reset to factory defaults. If there isn't one look here: and find your router and try the default username and password. If you do end up resetting to factory defaults then look at the link above and use the default username and password to get into your router.
May 18, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
196 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
