Question about Toshiba e-Studio 3540C Multifunction Color Copier
Toshiba estudio 3540c LD tray jams
The LD paper tray holding 8.5 x 14 size paper jams every time we attempt to use it. Removing the jams are simple, but because it jams each use nothing is able to be printed on the larger size paper.
  • 653 Answers
SOURCE: automatic document feeder
U need to check whether the flap-exit is working or not.
http://img.photobucket.com/albums/v390/anthonydidi/flap_exit.jpg
Posted on May 12, 2009
  • 125 Answers
SOURCE: I have a toshiba EStudio 162 error message L100-00 how do I fix
Hi:
If the error code is an L-1 the most lokely cause is the scanner lock on your machine is engaging with the scanner assy. Bend down and look at the left front corner of the copier right inside of the area where you grab your copies. You should see a clear round plastis knob. This has to be in the fully unlocked position If it is partly turned then this can be stalling your scanner assy and throwing the error code your seeing.
Good Luck
Andrew
Posted on Jun 27, 2009
  • 10 Answers
SOURCE: toshiba estudio 200 keeps having false paper jams
sorry,,, it is not feed roller problm, (not every time same couldbe happen with feed rollr) ghost jams bothers with cassette
Posted on Oct 16, 2010
SOURCE: No cassette with paper of size requested is available
Toshiba eSTUDIO 166 ''No cassette with paper of size requested is available''
Naeem Shoukat
Posted on Nov 02, 2010
  • 653 Answers
SOURCE: TOSHIBA eStudio 167, connected as
Try double check the paper size settings on the driver.
Posted on Nov 09, 2010
Paper jam
I havent used this model but there's a panel at the back that you need to open, behind the paper tray, in order to remove the paper jam
Mar 16, 2014 | Toshiba EStudio 223 Copiers
TOSHIBA ESTUDIO 455,PAPER GETS C FOLD FROM TRAY 2 IN A4R AND GETS JAM IN A4,BUT FROM BYPASS & FIRST TRAY A4R & A4 OK,EXCHANGED FEED ASSEMBLY,FEED CLUTCHES,REGISTRATION CLUTCH EVEN COMPLETE DUPLEX...
Try looking for distorted paper guides and trace the paper passages for any disposition or maybe foreign object stuck on it. try shuffle the papers too.
Apr 17, 2013 | Office Equipment & Supplies
I can't get my toshiba estudio 162 copier to print 8.5 by 14 inch copies. how can i change the length?
Drawer feeding:
A3, A4, A4-R, B4, B5, B5-R, LD, LG, LT, LT-R,
FOLIO, COMPUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-R
Bypass feeding:
A3 to A5-R, LD to ST-R, FOLIO, COM-PUTER, 13"LG, 8.5" x 8.5", 8K, 16K, 16K-R
Jun 25, 2012 | Toshiba e-Studio162D Copier
Toshiba estudio 161 don't change paper tray
THERE ISN'T PAPER IN TRAYS OR SWITCH OFF ON PANEL
Apr 28, 2012 | Toshiba Office Equipment & Supplies
Naeem Shoukat
Feb 16, 2010 | Toshiba e-Studio163 Copier
Paper Error
The paper lift housing is cracked. The clicking noise is made by the lift gears skipping teeth.
It needs to be serviced...in the mean time, you might try feeding 11 x 17 paper through the manual feeder (bypass tray). Or if you need many 11 x 17 copies, it is possible to set another paper drawer to 11 x 17 size...just set the plastic tag in the front of cassette to LD so the machine knows what size of paper to expect (if tag is set incorrectly, machine will jam EVERY TIME)
Jun 10, 2009 | Toshiba E-STUDIO 450 Copier
Automatic document feeder
May 12, 2009 | Toshiba Estudio 200L Copier
Toshiba estudio 200 keeps having false paper jams where are paper sensors located?
its not the paper sensors you need to get to its the feed rollers,which will be above the paper tray near either the left or right side of machine. clean those with glass cleaner. if they appear smooth in any way they should be replaced, keep old ones to compare. what you are referring to as false jams we in the copier world call the "ghost jams"
May 08, 2009 | Toshiba Estudio 200L Copier
HPS Copy Machine; paper size settings not adjusting correctly, malfunction, misfeed in copier, repeat, repeat, repeat
there are user mode settings and also some have settings on the actual trays the little windw that shows the paper size on the tray open tray ther is a slot that a cut out plate with the paper sizes make sure the correct size is showing thru the window if not reach in and pull out the cut out and put back in with the correct size displaying thru the window 81/2 x 11 and R if your copying the long way hope this helps
Apr 28, 2009 | Toshiba Estudio 200L Copier
Toshiba e-Studio 3540C Multifunction Color Copier Logo
66 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
