Question about Radial Drills
Cannot locate a manual for a Canwood Pro Radial Drill Press, model CWD-11-350
5/8 chuck. We also cannot locate a chuck key.
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
efs_perpends
  • 1996 Answers
SOURCE: Parts and manuals
You can download a .pdf copy of the manual for your drill press by clicking here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Craftsman Drill Press chuck problem
It is unless there is a tang on the end. What you need to do is thoroughly clean the parts with something like brake clean to remove all the oil and then wipe with a clean paper towel. What I do it put the arbor into the drill press or the chuck onto the arbor and then put a 2x4 on the table and press the parts together or if you have enough room fully retract the jaws and use the block of wood to "tap" the parts to seat them. Let me know if you need more assistance
Posted on Aug 25, 2009
Testimonial: "Thanks rowdy45176. Your solution was spot-on. I cleaned both sides and them , with the chuck jaws fully retracted, tapped it with a plastic mallet"
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    How to remove the chuck on bench drill model bd 315
    Well I'm guessing BD = Black and Decker and that it has a conventional chuck key?
    If so insert chuck key into chuck as you are about to tighten chuck onto a drill. Then, holding the drill firmly by the chuck end and using a wooden mallet; give the chuck key a sharp blow in the opposite direction to which the drill turns. The shock of the impact should enable you to simply unscrew the chuck by hand from here on.
    Dec 01, 2013 | Drills
    Chuck key
    Go to a Harbor Freight Store or you might be able to get one one line. They have the replacement keys for the Central Machinery Drill Press.
    Jun 15, 2013 | Central Machinery Mortising Machine
    Replace Keyed Chucks with Keyless Chucks
    Can't help with this other than suggest that you do not proceed, Keyless chucks can be problematic particularly if dust /debris from material being drilled finds its way into the chuck..
    Mar 30, 2017 | Drills
    I have a 0302-20 1/2 drill how do i remove and replace the chuck ? i have the bolt out of center.
    Chuck the handle of the chuck key in the chuck.Find a drill bit that fits in one of holes that the chuck key fits in.Then use a flat screw driver to lever off of the drill bit and the teeth to tighten the chuck .Use a towel and hold the drill motor,be careful not to squeeze to tight just enough to hold the drill from moving.Use a harmer and strike the chuck key and that should loosen the chuck.A 1/4 inch chuck key will work as well.If this is a key less chuck then use a small pipe wrench and hammer on the back part of the chuck with the handle left as you look at the drill.Good Luck & Thank You for choosing FixYa.com.
    May 17, 2011 | Milwaukee Garden
    I can not change the drill bit. Do I need another tool?
    that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
    Feb 24, 2011 | Drills
    How to fix the bit
    If your Makita matches the one on the picture, you will need a chuck key to attach a drill bit or tool to the machine's chuck. The chuck key inserts to any of the small holes in the front part of the chuck and at the same time its teeth interlocks with the teeth of the chuck. When turning the chuck key you will widen or loosen the grip of the three jaw pieces, that clamps to your tool or bit. Tighten the chuck key by hand until the chuck grips the bit securely. For safety, unplug the power cord whenever operating the chuck key on the chuck.
    Jan 09, 2011 | Makita & 1/2 Inch Drill
    3/8 Drill Driver, chuck replacement.
    hi friend,
    Step 1. Determine what kind of replacement drill chuck you want - a keyed chuck or key less chuck. Over the years, key less chucks have been widely used for handheld power tool drills, due to their improving grip torque and convenience.
    Step 2. If you prefer replacement key less chucks, then you have to know what type of key less chuck you will need - a single sleeve key less chuck or a double-sleeve chuck. You can simply determine it by checking your current chuck. If your current chuck is a keyed chuck or a double sleeve chuck, then you will need a replacement double-sleeve key less chuck. On the other hand, if your current chuck is a single sleeve chuck, then you should get a replacement single sleeve chuck.
    Step 3. Confirm the threaded mount size (spindle size) on the chuck. 3/8"-24 threaded mount for 3/8" capacity drill chucks and 1/2"-20 threaded mount for 1/2" capacity drill chucks, but there are some exceptions where just the opposite may occur. To be safe, always check the threaded mount before you buy replacement drill chucks.
    hope this helps u
    please rate me.........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
    Drill chuck swap
    1. Turn the screw clockwise to take it out.
    2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
    3. hold the drill at the edge of the table & wack the allen key
    counter clockwise & do it again as needed.
    4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
    5. putting it back together the other way.
    Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
    Dewalt dc920 repair instructions chuck
    To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
    Instructions for removing a keyed chuck
    Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
    1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
    2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
    3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
    There is no way to stop the motor from turning.
    It may require several attempts to loosen the chuck
    Instructions for removing a keyless chuck
    1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
    2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
    Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
    Drills Logo
    184 people viewed this question
    Top Radial Drills Experts
    Are you a Radial Drill Expert? Answer questions, earn points and help others
