Question about Sony SNCRZ25N Network Camera
Cannot detect configure SNCRZ25
Brand new camera, once I conect the power...network and power leds comes on, however after a few seconds and a quick lens movement power led goes off and network led stays on even though I have no network cable connected to the camera. Your help will be very much appreciated. Regards
Power supply. I tried 500 m.a. No good. 1000 m.a. @ 12volts Rocks the house. The manual fails to mention this, Since we supply our own on this model.
Posted on Oct 08, 2008
SOURCE:
HP Designjet 500 has a locked screen. I have been trying to get the plotter to run on our new computer and it locked up after installing the current Firmware and driver updates. Any suggestions would be...
Dear Friend, It's a serious issue what I understood & confusion is control panel locking facility not avail in this model, how its locked?.. Simple method to catch the faulty part through power LED behaving s..(Power led located on power button)
# LED is OFF - This indicates that the Power Supply Unit is
completely dead. Try the following:
1 Check that power cord is connected correctly to the Printer and to the Power Socket.
2 Replace the Power Supply Unit
# LED is ON (all the time) - This indicates that the Main PCA is completely dead. Replace the Electronics Module
# LED is Flashing - A problem has been detected with the previous firmware upgrade. Try re-send the firmware upgrade file.
# LED Flashes twice every few seconds - The Printer cannot detect the Interconnect Cable. Try the following:
1 Check that the Interconnect Cable is connected correctly to the inter connector PCB & Electronic module.
2 If the Interconnect cable is connected correctly and the LED continues to flash twice then replace the Interconnect Cable
LED Flashes 3 times every few seconds - The Printer cannot
detect the Front Panel. Try the following:
1 Check that the Front Panel is connected correctly to the Interconnect PCA.
2 If the Front Panel is connected correctly and the LED continues to flash 3 times then replace the Front Panel
LED Flashes 4 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module
LED Flashes 5 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module.
Now U decide that whether firmware uploaded properly or not?..if not its sure that Electronic module gone.. you have 2 replace it..
Any further help/query pl reply, best of luck..
Oct 02, 2013 | HP DesignJet Office Equipment & Supplies
Wont switch on
Solution three: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
Apr 07, 2010 | HP Photosmart C5180 All-In-One InkJet...
Need to conect with wireless card to internet. moved and am trying to connect to my neighbors wireless modem with his permmision of course. windows message is that it cannot configure wireless connection....
Once you detect his network he wil need to give you his encryption key in order to connect. Otherwise you will be denied.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Trunking problems
  1. u may need to check first internal network broad casting. if any system is giving too much packeting
  2. connectors of cables which is properly crimp
  3. quality of cable
  4. cable which is comes in ur premises through area junk box is properly connected.
  5. u may need to check load balancing of network from your authorised vendor
Apr 06, 2009 | Cisco Catalyst 2950SX-48-SI 48-Port...
Samsung L703 didital camera wont turn on
For me also same problem No power ON Green LED blinks
Oct 28, 2008 | Samsung Digimax L730 Digital Camera
Problem with modem
If the Online LED on your modem is red, it means that it is not synchronized with the connection that you have from your Internet provider.
Try to reset the modem by holding its reset button for 30 seconds then power it off. After 10 seconds, power it on and observe the Online LED.
If you also have a username and password from your Internet provider, you may set those on the modem configuration.
Sep 08, 2008 | Siemens SpeedStream 2624 Router...
Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
May 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
Asus Router Offline
hello!
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Hitachi 61UDX10B
[BRAND SPECIFIC][TOSHIBA][QUICK FIXES]
Flashing LED
<< Back to Quick Fixes Page
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Jan 22, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Panasonic bl-c20 wireless network camera
Try this - unplug the power from the camera (and the ethernet cable if it is using one). Locate the 'Factory Default Reset' button on the camera get a paperclip and straighten it out. Plug the power back into the camera and press the reset button with the paperclip until you see the indicator light flash and go out (about 10 seconds). Now attach the ethernet cable to the camera and into your router and insert the Panasonic camera utility disk into your computers CD Drive. Run the setup utility from the disk and after a few minutes it should find the camera and you can follow the instructions for a new set-up. If the camera has been on more than 20 minutes when you start the setup utility, unplug it for 10 minutes and try again. Oh, and turn off Windows firewall while you are doing this.
Oct 31, 2007 | Panasonic BL-C30A Network Camera
Sony SNCRZ25N Network Camera Logo
177 people viewed this question
Top Sony Home Security Experts
JonSnell Electronic
JonSnell Electronic
The Los Man
Level 1 Expert
Nitin Khatri
Nitin Khatri
Are you a Sony Home Security Expert? Answer questions, earn points and help others
