1999 Pontiac Grand Am GT Logo
Posted on Jan 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
150,000 mile service for a 1999 Pontiac Grand Am SE??
What all should be involved in a serive for a 150,000 mile tune up on a Pontiac Grand AM (1999)? I called around and all the shops told me it would cost around a $1000.
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Jan 27, 2009
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
21019
Points
145
150,000 you should have the brakes checked, check brake lines, tune up (spark plugs, wiers, air filter, ect.) rotate your tiers replace if needed, oil change, be sure to change your cabbin filter to, most people don't know that their car has a cabin filter. The shop should tell you exactly what they would do to it.
If you have any questions E-mail me at [email protected].
What's involved in a 150,000 mile tune up for my 2003 crown Victoria
Outside of filters, maybe the PCV and spark plugs if not changed at 100,000 miles with Iridium .
2helpful
2answers
Grand vitara tune up
Run fault codes and see what faults are recorded. If there are no recorded faults and the vehicle stars and runs and changes gears as it should then the CPU has the tune up in order and you do not need to spend any money.
Radio won't work in my 1999 Pontiac Grand Am SE
Check your fuses. I belive the radio fuse is on the passenger side of of dash where it meets the door.
1helpful
Signal lights work intermently on olds 2002 and 2001 models, what could be causing this problem?
A defective electronic flasher relay will cause this problem. GM has a problem with these, please read on.
GM
Bulletin No.: 04098A
Date: January 11, 2006
SPECIAL POLICY
Subject:
04098 - Special Policy Adjustment - Turn Signal/Hazard Warning Flashers
Models:
1999-2002 Chevrolet Malibu
1999-2002 Oldsmobile Alero
1999 Oldsmobile Cutlass
1999-2002 Pontiac Grand Am
Supercede:
This bulletin is being revised to include 2001-2002 Chevrolet Malibu, Oldsmobile Alero, and Pontiac Grand Am vehicles. Due to part availability, it is anticipated that customers will not be notified until late April 2006. In the meantime, should a customer bring in a 2001-2002 Chevrolet Malibu, Oldsmobile Alero, or Pontiac Grand Am vehicle because the turn signal/hazard warning flashers are inoperative, repair the vehicle as described in this bulletin and submit the claim using the labor code found in this bulletin.
Please discard all copies of bulletin 04098 issued December 2004.
Condition
Some customers of 1999-2002 Chevrolet Malibu, Oldsmobile Alero, Pontiac Grand Am, and 1999 Oldsmobile Cutlass may have turn signal/hazard flashers that become inoperative.
This special policy covers the condition described above for a period of 10 years or 150,000 miles (240,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
For 1999-2000 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after December 23, 2004 are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to December 23, 2004 must be submitted to the Service Contract provider.
For 2001-2002 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after January 11, 2006 are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to January 11, 2006 must be submiffed to the Service Contract provider.
Is 150,000 on a 2002 Pontiac Grand Am bad?
Not sure how to answer this, if you have records of service and evrything that has been fixed right over the years its not bad. If its just had oil changes and little else it could last for 50 or 50,000 miles, its a gamble. If it was me i would buy it if it was going to be be a throw away car and not my daily driver just a spare.
What color of antifreeze do a 2002 pontiac grand am use
Hello and welcome. this vehicle uses red coolant. the coolant is know as Dexcool. this coolant is good for 5 years or 150,000 miles.
1helpful
1996 Grand Prix: How much for a tune up for my Pontiac Grand Prix S...
spark plugs, wires, oxygen sensors, fuel filter,air filter, oil, oil filter and while your at it, ac filter. In AL it will run you about 200 done yourself.
2helpful
How long do the 2001 pontiac grand am's normally last?
If the car was maintained according to the instructions in the owner's manual it can easily go 150,000 miles with no major problems. But if the car was neglected or driven hard, it could have major problems in as little as 50,000 miles. So as you can see it all depends on how the car was driven and how it was maintained.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
