Question about Maytag MVWX500XL High-Efficiency Bravos X Top Load Washer - Lunar Silv
Stuck in sensing mode
Washer lights up, goes into the sensing mode and stays there. Will not wash or anything. Washer is clean.
2 Suggested Answers
FAV6800AWDIY
  • 526 Answers
SOURCE: my washer was stuck in wash mode for the 10 hours ...
We are talking about a FAV6800A or FAV9800A machine correct?
You will need the Service Manual for reference. Sears Parts Direct for reference.
Do you want to try to fix the issue or call in a repair service? I will need someone who is handy to work with. We would need to power down the machine by dissconnecting the 120VAC power cord to the washer and removing the front cover of the machine and check to see if the Clutch Pulley will rotate CW and CCW direction. Let me know if you want to proceed to DIY..........Rich
Posted on May 24, 2010
May tag centennial top load washer will not agitate clothes
The most common cause of this is a defective washer lid switch. Follow the link for a repair guide. How to Replace the Lid Switch Lock Assembly on Top Load Washer Repair...
Jul 13, 2017 | Washing Machines
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Model # MVWC425BW0 Maytag Centennial
May have to reset your washer to default mode or unplug for a few minutes then plug back in. It should work after that.
Mar 11, 2016 | Maytag Washing Machines
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
My whirlpool cabrio will not work it stay on the sensing it will no t run at all
Hello. Carefully listen for a faint, rhythmic, buzzing sound. Is it there? If so, the problem is most likely the motor run capacitor underneath the unit is defective. I really need the model number of your unit to help you more accurately. If you hear nothing at all, and nothing is happening(i.e. the washer sense light just stays on with total silence) you might have an actuator problem. The actuator is literally an electric shifter that shifts the transmission of the washer from agitate mode into spin mode and back. Also, do you have well water or city water? Is the unit filling with water at all? If you live on a well and the unit is filling with water very slowly, the computer might be timing out--this is indicative of a clogged cold water inlet screen, located inside the cold water hose connection at the back of the washer.
Aug 22, 2015 | Whirlpool Washing Machines
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
Wash light remains on WTW5500XW
Sounds like a bad main board , Good thing its new under warranty
Dec 12, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
Maytag MVWX500XL High-Efficiency Bravos X Top Load Washer - Lunar Silv Logo
515 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
