Question about Epson FX-980 Matrix Printer
IMPRIME A LA MITAD DE LA HOJA Y NO IMPRIME COMPLETO
BRINCA A LA SIGUIENTE HOJA PARA SEGUIR IMPRIMIENDO EL FALTANTE
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: ESTA DESCONFIGURADA...IMPRIME LAS PAGINAS
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
whurtado
Este es lo que algunos llaman un "Sistema de caducidad programada", es por culpa de un comtador interno que tiene la impresora, llaga a cierto numero de impresiones y se niega a seguir imprimiendo hasta que la lleves al centro de servicio autorizado.
Pero hay una herramienta que se llama "ssc service utility", ese software sirve para desbloquear las impresoras EPSON, te paso el link para que lo veas:
http://goo.gl/sGkgQg
Posted on Oct 31, 2013
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Hola mi problema es el siguiente, no puedo escanear con la multifuncional Lexmark serie 2500 me sale el error App4R.exe necesito solucionarlo para seguir escaneando con urgencia.. Gracias.
Intente volver a instalar el controlador de la impresora. Visite el sitio Web de Lexmarkpara descargar el controlador X2500 en http://bit.ly/aKlcOJ. Seleccione el sistema operativo, descargue y ejecute el archivo.
(Esto se traduce con http://translate.google.com.)
Apr 12, 2011 | Lexmark X2500 All-In-One Printer
Impresora lexmark e352dn imprime una hoja seguida de una hoja blanco
Por favor, intente comprobar la configuración del procesador de texto que está usando antes de imprimir. Compruebe el número de páginas que va a imprimir. También puede hacer esto para ver haciendo clic en la vista preliminar, si hay una página adicional, compruebe la configuración de su procesador de textos de nuevo.
Para obtener asistencia adicional, p?ngase en contacto con asistencia t?cnica de Lexmark..
Jan 13, 2011 | Lexmark Lemark E352DN Laser Printer
EN LA PORTATIL ACER ME LEE EL DISCO SIN PROBLEMA, PERO CUANDO CONECTO EL DISCO USB PORTATIL VERMATI EN MI CPU CORE 2 DUO QUADZ ESTE NO LO LEE
Apreciado endor74,
Tu disco duro externo podria estar averiado o tener la tabla de ficheros corrupta. Por favor descarga la siguiente aplicacion de Seagate para verificar si es por motivos de hardware:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Si no te indica ningun problema de hardware, te recomiendo que utilices la siguiente aplicacion de OnTrack para intentar recuperar los datos todavia accesibles:
http://www.ontrackdatarecovery.co.uk/data-recovery-software/easyrecovery-lite/
Si no aparece ningun dato como accesible y recuperable, entonces solo queda la opcion de formatear el disco de nuevo. Te recomiendo esta guia que puedes seguir paso a paso para formatear el disco:
http://www.ehow.com/how_6026_format-hard-drive.html
Cordialmente,
Eddie Knight
Dec 28, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
TENGO UN MENSAJE QUE DICE: CUBIERTA TRASERA ABIERTA,COMO PUEDO SOLUCIONAR ESTE PROBLEMA EN EL PRINTER MFC-7820N\r\n GRACIAS
La solucion que me ha funcionado para una Brother DCP-7010 ha sido:
1.- Abrir la puerta trasera
2.- Bajar la cubierta trasera que esta justo delante del fusor. Para ello he pulsado hacia abajo las dos palancas de plastico azul en los laterales.
3.- En el interior de la cubierta, en la parte inferior derecha hay una barrita de plastico horizontal que aproximadamente en la mitad tiene un saliente (una barrita perpendicular de plastico). Dicho saliente debe estar metido en una ranura que tiene la cubierta trasera, en mi caso se habia salido.
4.- Una vez metido el palito en la ranura se cierran todas las puertas.
5.- Ponemos en marcha la impresora y vemos que ha desaparecido el error y ademas imprime.
Saludos.
Mau
Oct 10, 2010 | Brother MFC-7820N Printer
ESTA DESCONFIGURADA...IMPRIME LAS PAGINAS INICIANDO DESDE LA MITAD DE LO QUE SE VA A IMPRIMIR EN LA PARTE DE ARRIBA DE LA HOJA
Hi there
May 05, 2010 | Epson Stylus 1400 InkJet Photo Printer
Epson FX-980 Matrix Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
