Question about Nesco Crock Pots & Slow Cookers
Como reset Nesco pressure cooker pc6-25 e4 - Nesco Crock Pots & Slow Cookers
  • 7 Answers
SOURCE: E4 Code
The E4 Code, in my experience, occurs because the element is overheating.
What I found fixes this problem is a good cleaning of the bottom of the insert and a further thorough cleaning of the Heating Plate inside the the cooker itself that he insert rests on.
Hope this is of help to someone who has the recurring "E4" code with the Barvetti Pressure Cooker
Posted on May 11, 2009
buffalonyman
  • 1865 Answers
SOURCE: Can I eplace a heating element for a Nesco cooker.
water won't hurt the heating element
Posted on Aug 19, 2009
  • 6 Answers
SOURCE: E4 on the Woldgang Puck Electric Pressure Cooker
Before using the pressure cooker make sure the bottom of the container is dry.. I got this error then i just wiped of the bottom of the inner container.. turned off the pressure cooker then turned it on again.. it worked fine after that.. no more error
Posted on May 24, 2010
  • 6 Answers
SOURCE: e4 on pressure cooker how do I fix?
make sure the inner container is dry.. use wipe of with a towel. plug he unit off then on again
SOURCE: displays E2 and E4 (5 qt Wolfgang Puck pressure
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Posted on Jun 16, 2012
I need a harvest pro pressure cooker manual
I couldn't find a manual for you but I found the manufacturer's website so that you can contact them for a replacement.
https://www.getpressurepro.com/
BTW, I noticed that the informercial and website says that you can pressure can in that pressure cooker. That is actually not safe to do, there are no USDA-approved pressure canning processing times for electric pressure cookers. Here is a comsumer alert with details:
http://www.hippressurecooking.com/consumer-alert-no-pressure-canning-in-un-tested-multi-cookers/
Sep 08, 2015 | Nesco Crock Pots & Slow Cookers
Does anyone know where I can get the pressure cooker lid for the epc460
WI 1-800-288-4545 (web site www.nesco.com
They might be able to help you. th eoriginal cooker qwas sold by QVC and the original company, Cook's Essentials, is out of business.
May 19, 2015 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
TONGTEL PRESSURE COOKER
Take a look here for pressure cooker instruction manuals:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Mar 25, 2014 | Nesco 6qt Electric Pressure Cooker Pc6-25...
Presssure valve to be turned off or on when using pressure cooker
pressure cooker cooks by the pressure inside the cooker.
So you need to put those on when cooking.
The excess pressure will automatically drain off.
Jun 12, 2012 | Nesco Electric Pressure Cooker
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Error code keeps flashing wont pressure up and they wont stand behind their product
The vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Mar 09, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
Pics of process:
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Crock Pots & Slow Cookers Logo
37 people viewed this question
Top Nesco Crock Pots & Slow Cookers Experts
ZenFire
charles
Sock Puppet
Are you a Nesco Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
