Question about Tools & Hardware - Others
Duracraft belt sander manual
Need to replace sanding belt. Manual would help
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
SOURCE: need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
Posted on Oct 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: The Belt of my craftsman 3x21 sander slowly moves off track.
could be a couple things, first are you using directional belts and are they on correctly and look at the front roller to make sure it rotates freely, also look aat yoke for being bent and the tensionins mechanism moves freely. Let me know if you need more assistance
Posted on Dec 14, 2009
seanpwright
  • 2030 Answers
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Posted on Apr 02, 2010
  • 40 Answers
SOURCE: I need manual for Craftsman 315.11720 belt sander
On my model 315.11720 3"x21" Craftsman belt sander to change out sanding belts you push the front roller in until it clicks to lock in its retracted position (a pry bar may help here), switch out sanding belts then unscrew the tracking tensioner a bit on the opposite side with a allen wrench until the roller snaps back in place. I never remember anything about using a screw driver to force it back forward position again. Then readjust the tracking if necessary with a few short sanding load tests and you're good to go. Oil is dropped in the front roller center by removing the flat head screw - it should say "Oil Here" around the screw.
Posted on Aug 19, 2010
How to replace the sanding belt
Google the model number and "manual".
Mar 24, 2014 | Rockwell RK7866 Belt Disc Sander
Looking to download a manual. need replacement belt
Hello,Breez ,
Maybe you already have the solutions for you,re manual sanders download .If not look on internet search on google ,jet sanders manual and there you go further . For pdf file ,you should download A free adobe reader if neccesary.
Free of charge.
Appie
May 07, 2011 | Jet Tools & Hardware - Others
Looking for replacement parts for a Duracraft model s6436 sander
I am looking for a switch for a Duracraft Belt/Disc Sander Model # S6436
Nov 22, 2010 | Garden
Need a manual for a Craftsman belt & circular sander
Oct 21, 2009 | Tools & Hardware - Others
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Dec 26, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
29 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
