Question about Emerson EM-MS9700 6 CD-Changer stereo system Shelf System
What fuse does the Emerson MS9700 stereo use?
I lost my fuse to replace in my stereo and the manual does not tell me anything about a fuse. what fuse does it use.
5 Suggested Answers
informatica
  • 1113 Answers
SOURCE: Setting Alarm on Emerson ES2
You can download thee manual from the following link: http://www.emersonradio.com/owners/Micro%20Stereo/
Posted on Jul 24, 2007
SOURCE: Emerson MS9700 CD Shelf System - CD Tray won't open
You have to unscrew the whole thing and take the whole metal covering off and then the inner tray will be displayed and then you can just take the CDs out and then screw the cover back on. Happened to me, and that worked :]
Posted on Jun 07, 2008
I had the same exact problem.  When I opened it up, I found that a small rubber-band in the tray opening mechanism has slipped off.  While it was a simple problem, I caused more trouble by breaking a small switch while I was opening it, so be careful if you do decide to open it up.
Posted on Nov 26, 2008
SOURCE: Emerson ms9700
The disk would not spin. Removed 3 screws holding top "bearning deal" trying to remove it. could not get it off but disk would then spin. Worked even when i put screws back!
Posted on Jul 28, 2009
caroldon
  • 17129 Answers
SOURCE: Everything works on my emerson
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Posted on Nov 19, 2010
Where can I find a owners manual
http://www.emersonradio.com/resources/owner_manuals/manual_1312902799.pdf
Nov 07, 2015 | Emerson EM-MS9700 6 CD-Changer stereo...
Cd stereo says no disc
The player mechanism may have failed.
Sep 08, 2014 | Emerson EM-MS9700 6 CD-Changer stereo...
My emerson md9700 cd player wont operate, how can i fix it?
Does it power on?
If no, and if you're lucky, you can change the power supply
Oct 13, 2013 | Emerson EM-MS9700 6 CD-Changer stereo...
Can I change the frequency from radio to infrared in order to use the Logitech Harmony 650 infrared remote control
You want to use a Logitech Harmony 650 remote to control an Emerson shelf system, so what's the problem?
Nov 25, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
Change radio frequency to infrared frequency for the emerson MS9700
I very much doubt your Emerson unit uses radio frequency for remote control
Have a Emerson 6 chger CD/am/fm system. Do I need the remote to use the CD player?
Buy one universal remote control, which have setup codes for your device. Brand name isn't a matter.
May 06, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
Emerson ms9700
one thing that you can do and this helped me when i had that same problem is to take off the top cover and clean the laser lens
Oct 25, 2008 | Emerson MS9700 CD Shelf System
Aug 26, 2007 | Emerson MS9700 CD Shelf System
Top Emerson Audio Players & Recorders Experts
Blake
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
