Question about Copystar Office Equipment & Supplies
Copystar 2020 is reading error E31
What is meant by toner disposal
  • 26 Answers
SOURCE: I have a Copystar CS-2020 and it is showing error
Document Processor communication problem. This is due to a faulty ground connection.
Open the doc feeder lid, check the left hinge. There are two versions of grounding tab: a small one and a bigger and better one. Both attached by a screw.
Twist the small metallic tab that grounds the hinge with doc feeder metal frame in order to create better contact. Worst scenario, the doc feeder cable has a broken ground wire at the holding strap (inside the back rear cover of the feeder, which is hold in place by plastic clasps. If you are handy you can solder the wire ..
Posted on Feb 21, 2009
  • 153 Answers
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
Posted on Jun 01, 2009
FixinFax
  • 3085 Answers
SOURCE: The "dispose of used toner" error message will not clear.
Wash out the bottle with soap and water.
Posted on Sep 25, 2009
goodgold
  • 389 Answers
SOURCE: our copystar 2030 keeps asking for toner. We just
Can be an ensemble of the reasons:
1. The Silent sensor which checks the concentration of the toner.
2 Check pulled of you film defensive with tubas?
3 During moving the toner track can be broken or littered.
4 Can be a value-added degree to concentrations of the toner in service programme inflexion
5 Can be sensor itself to concentrations
7 Sensors can be littered
8 If it is used developer, can be violated concentration developer to toner
This in a complicated way repairs with words.Sooner whole you should apply to service,forgive, but such fault it is difficult do advice, it is necessary all look the experienced specialist, you may lose much toners and break the track of the presenting the toner, apply to service. Good luck
Posted on Oct 09, 2009
n25an
  • 622 Answers
SOURCE: we just need a manuel for the copystar 2020 free
try usa.copystar.com... if its not an american model then goto the main copystar site... copystar.com and search for your region and then search the support section or download section for your manual... if you want a service manual google it and many places online will gladly sell it to you...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 26, 2009
ERROR CODE E31
Hi and Welcome to Fixya!
E31 simply means - Waste Toner Reservoir Overflow Problem (when the total number of copies is more than 100K sheets). After E31 is displayed, 1000 sheets may be copied before shutdown.
Hope this helps!
Takasashi
Jul 13, 2011 | Kyocera Copystar CS-1620 Black and White...
WHAT DOES CODE C7990 MEAN ON A COPYSTAR CS-1820
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Mar 30, 2011 | Copystar CS-2030 Copier
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
I just put in a new toner cartridge but the printing is so light i can barely read it
The new ink cartridge has a plastic lining requiring removable before snapping in placement area on printer. Inserting a new cartridge without removing the plastic lining safe requirimng disposal would least produce results upon installing cartidges. Good lcuk
Jan 11, 2011 | Copystar Office Equipment & Supplies
Error E31 Kyocera KM 1620
this is an error code for slow warm up you should pull the fuser out and check the thermistors and condition of the rollers. sometimes the thermistors get caked in toner so they cant read the temps correct. if you take the unit apart you should be able to detect the toner build up. a soft clothe and some WD40 may be able to clean it off but be ccareful as too rough may clip ther resistor off.
Jul 12, 2010 | Kyocera Copystar CS-1620 Black and White...
We just need a manuel for the copystar 2020 free download would be good.
Nov 04, 2009 | Copystar CS-2020 Copier
E33 Error Message
Im pretty sure the E33 error means the toner is empty, so you need to replace the toner.
If you have already done this, make sure everything is correctly seated and firmly closed.
Here is the manual incase you get any other problems, page 95 addresses your mentioned problem..
Copystar CS-2020 Manual
Regards
Mike
Sep 03, 2009 | Copystar CS-2020 Copier
Error E31
The waste toner box is full. Replace it with a new waste toner box.
Aug 14, 2009 | Kyocera Copystar CS-1620 Black and White...
Im getting an f2 error code in my copy machine sharp 2020
SHARP 2020 F2-31 ID sensor error SHARP 2020 F2-32 ID pattern reading error SHARP 2020 F2-33 Grid voltage error SHARP 2020 F2-35 Grid voltage error
probably need a part
Oct 15, 2008 | Copystar (023-JF503) Fax
Printing Too Light
9 times out of 10 when a copier is printing light it is NOT the toner.
when the toner is low the machine will display a message.
can you tell me how many pages this machine has done?
(hold the stop button to get a meter reading)
May 07, 2008 | Copystar CS-1510 Copier
37 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
