Question about Brother P-touch PT-80 Label Printer
Model pt 80 tape doesn't feed. have changed both batteries and tape still doesn't work
3 Suggested Answers
SOURCE: pt-110 problem
I have the same problem. There is a little arm attached to the base of the pinch roller. It's broken on mine causing the problem. Attempted to epoxy the part back together, did not work, part is too small where broken. Don't know if there is a replacement part. New P-Touch was $39.00 at Staples so I'll probably just buy a new one. You have to be pretty mechanically inclined to get the thing apart anyhow.
Dave
Posted on Sep 28, 2008
komguy
  • 2306 Answers
SOURCE: Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Posted on Sep 17, 2009
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
I am trying to load a new roll of labeling tape into the Dymo Organizer 1610. But the tape doesn't advance properly into the front part of the machine that does the printing.
Before inserting the tape into the feed mechanism, bend the last 1/8 inch of the tape upward at a slight angle. This will insure that the tape feeds properly. I just learned this by trial and error.
Aug 03, 2011 | Office Equipment & Supplies
Cassette tape on boombox (panasonic '80/'90) won't play & when it does it eats the tape.
Hi, I remember this problem. Your " take up spindle " isn't turning. This will be the one that also fast forwards the tape, so if the fast forward doesn't work you probably have a bad rubber band that drives it, or motor for a more sophisticated model. Also this symptom could be cause by debris that has built up on the " capstan " the little silver spike that will be close to the tape heads ( also on occasion has caused tapes to be eaten-so make sure it is clean, rubbing alcohol for this-same thing for the capstan.) I hope this was useful, write back to let me know-even if it wasn't so I may try again, thanks for asking FixYa-good luck, Prodzilla
Apr 23, 2011 | Audio Players & Recorders
Have inserted new batteries and new cartridge but not able to print
Sounds silly, but are the batteries good and are they correctly installed. Check the pictogram in the battery case and make sure that the batteries polarity complies. Also check that the cartridge is securely fitted and the tape feed is correct.
Jan 17, 2011 | Brother P-touch PT-80 Label Printer
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
I have a Brothers home and hobby PT110 labelmaker. It has new batteries. I can type the words but the tape won't feed even though the labelmaker is making a sound as if it is about to print.
You have to make sure the new tape is snapped in and then put the back back on it. After its reassembled press CODE SPACE. This will feed through the tape. If the back of the P-touch is not on it will not work... Crazy but true :)
Dec 28, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Labeling system trouble-shooting
This is a duplicate post, click on the following like for the original: http://www.fixya.com/support/t133614-labeling_system_trouble_shooting
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
Brother P-touch  PT-80 Label Printer Logo
213 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
