Question about Canon imageCLASS D320 Digital Copier
Canon ImageClass D320 makes grinding noise at paper tray
Loud grinding noise (like plastic gears slipping) coming from paper feed tray area.
3 Suggested Answers
SOURCE: With Windows Vista and Canon imageCLASS D320
imageCLASS D320/340 Printer Driver Ver.3.00 for Windows Vista
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=164&modelid=9036#DownloadDetailAct
Posted on May 03, 2008
SOURCE: Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Posted on May 06, 2009
The red alarm light keeps blinking and as we open and close the right it make continuous noise at the bottom of the paper tray for 30 seconds and it don't catch the paper
the better call the technician.
because I think there is some gear has broken/loosen.
but first you can check it. perhaps that is just a rubber(pick up roll) was slick.
so can not catch the paper.
May 27, 2011 | Canon imageCLASS D320 Digital Copier
Canon d320 image class makes knocking sound and nothing prints
First be sure that your printer cartridge is Ok (not blocked). Did the Canon feed the paper? Can you print, or there is a problem with scanner section
pifonski
Feb 20, 2011 | Canon imageCLASS D320 Digital Copier
Crinkly noise
The noise is coming from the fuser film. You will need to have the fuser replaced to solve the problem. You may have to call a service company to replace it for you.
Nov 14, 2009 | Canon imageCLASS D320 Digital Copier
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Getting LCD Error: Toner not set Insert Toner
Sometimes what causes the problem is the black cartridge guide on the inside rear of the machine. It comes loose and so when you put your cartridge in it does not line up with the contacts properly. The parts cannot be ordered seperately. It comes with the whole rear assembly. The part # for it is HM1-0244
Feb 14, 2009 | Canon imageCLASS D320 Digital Copier
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Paper feed broken
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Mar 20, 2008 | Canon ImageClass MF5770 Laser Copier...
Canon imageCLASS D320 Digital Copier Logo
old marine
old marine
