Question about American Standard Colony Hydro Massage Bathtub Only AME
American standard hydromassage bathtub parts
M# 2732018020 need pump motor with air switch
3 Suggested Answers
  • 31 Answers
SOURCE: My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
Posted on Sep 30, 2009
uspartscente
  • 717 Answers
SOURCE: I bought a house with a american standard jet tub
yes. You will find a replacement pump at the following stores:
US Parts Center
Bath Parts Plus
Posted on Jan 25, 2011
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
Tub will not turn off
If your pump will not shut off when you push the button on the tub then you have a bad air switch in the motor.
Rod
US Parts Center
Nov 23, 2013 | American Standard Home
I have a American Standard Corner Whirlpool Year 10-10-03 Model 752857-300 When I push down The air switch button down The whirlpool come on But when Push again it will not cut off I check hose going to...
t sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Sep 27, 2013 | American Standard Home
Air switch
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
Search for TBS-339 Air Switch
US Parts Center
Have an American standard whirlpool tub. the on/off button is stuck on on. now the only way to shut the jets off is to flip the breaker to the bathroom. how do I fix this
This sounds like the air switch in the motor is not working properly. You will need to remove the pump from under the tub to access the air switch located in a housing on the motor.
Replacement Air Switch will cost you about $20
US Parts Center
Aug 27, 2013 | American Standard Home
My American Standard Whirlpool does not turn on. I push the Power button and don't hear anything. Circuit breaker is on, anyone have any ideas? Thanks!
Remove access panel make sure pump is plugged in some electricians put a GFI outlet under tub for motor make sure GFI did not trip. Next the switch is an air switch look for the hose going to switch is connected last you may need a new air switch which is common to fail
Nov 03, 2009 | American Standard 2770.018w.020 Cadet...
Sep 29, 2009 | American Standard 2770.018w.020 Cadet...
Air push button does not stop the runnig motor
Check the switch and air lines. You probably hear the switch clicking but not the pump. It probably goes into an air powered solinoid for the actual switch, away from the water. Ckeck those connections.
Mar 04, 2009 | American Standard 2770.018W.021 Cadet 5' x...
Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Jan 13, 2009 | American Standard 2770.018w.020 Cadet...
American Standard Colony Hydro Massage Bathtub Only  AME Logo
153 people viewed this question
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
