I have an av316 NAD, surround sound Amp. Just got back from repair. The wires to the speaker may have been reversed when hooking, the amp went into protection mode, can I fix this problem. It wont come out of this mode...thanks..John
I have a NAD AV316 and there it still saying protect on the display. speakers not in... help plz??
Posted on Feb 09, 2012
  • 4,234 Answers
Having the speaker wires hooked up backwords will not cause protect mode. If the wires were crossed (in other words shorted), that would. Disconnect all speaker wires, if the unit is still in protect mode, than the output transistors are probably shorted and the unit will again require service. Upon return from service, I would turn on the unit without speakers to insure that the unit at least works that far. Also, if you have an ohmmeter, measure across the speaker terminals. You should read either 3 or 6 ohms. If you read 0, the problem is a shorted speaker that then shorted the amp.
Keep us posted.
Dan
Posted on Jan 21, 2009
I get an intermittent loud hum using NAD AV316 amplifier, with stereo speakers(B connection) with phono input from Dual 606 turntable. Hum increases/changes when tone arm on turntable is touched.
The hum of course is the 60 cycle line AC voltage. Make sure that the routing of the AC power plug is as distant as possible from the stereo RCA cables.
The most likely problem is the connection of the phono cartridge to the wires in the arm. These connections usually are silver plated and become oxidized creating a bad connection. Remove the cartridge and using a fine eraser polish the connections. There is a ground connection that makes the five wire connection. Be super carfull these terminals are very easy to break
The phono connections to the stereo is very low voltage subject to interference. The connection to the magnetic pickup at the tone arm is low impedance and is inductive. Any poor connection between the cartridge up to the AV316 will produce this hum. Continue to check connections and swap cables with a known good to resolve.
I have switched the left and right cables to ensure that the cable is not the problem.
Hope this helps?
Sep 26, 2016 | NAD Audio Players & Recorders
Center Channel Low Volume, Tighten Jacks worked for about a week.
Reseated connections inside Amp. so far center channel is working, also plan to replace banana plugs used to connect speaker wires to Amp.
Jan 22, 2009 | NAD T742 Receiver
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Speaker set up problem
They hook to the rear surround.
Dec 20, 2008 | Audio Players & Recorders
Sanyo Audio component system 685, ran well until moved to another room. Plugged in and turned on unit. Used different copper antenna wire to hook up one speaker. Maybe cause of problem? The sound came on,...
It seems that the wire you used may have had a defect in that the two speaker wires may have touched each other and caused the amplifier to over drive and burn out . If you reverse the speaker that is not working to the other channel, it will work proving that the amp is dead and in need of repair.
Sep 07, 2017 | Kitchen Ranges
Orion 12000
the speaker out let on back of speaker box went bad and burnt the circuits in the amp
Mar 15, 2008 | Car Audio & Video
Rear speakers
THE 4 WIRES SHOULD BE FROM THE REAR SPEAKERS THEY GET WIRED INTO THE SURROUND SPEAKER OUT POSTS ON YOUR AMP (MAKE SURE YOU DO NOT GO INTO SURROUND BACK THIS IS FOR 6.1 AND 7.1 SYSTEMS).WHAT ARE THE WALL UNITS? NEED MORE INFO TO TRY TO HELP.
HOPE THIS HELPED A BIT.
CABLE GUY
Feb 13, 2008 | Onkyo TX-SR605 Receiver
Nad 214 amp
problem is- intermittent speaker relay. You can cleaned contacts or better upgrade relay to better one (sealed)  Dariusz
Jan 03, 2008 | NAD 712
No sound from Front Speaker
take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Mar 02, 2007 | Mission 700 Main / Stereo Speaker
478 people viewed this question
 Grubhead
Grubhead
