Question about Simac 4050 Il Gelatao Magnum 1 Quart Ice Cream Maker
Il Gelataio 800 motor quit, where can I get a new one or rebuild?
I have a Simac Il Gelataio 800 and the motor has stopped. Where can I get a new motor or get the old motor rebuilt?
  • GREENEYESBLU Apr 02, 2009
    I just had a similar problem. My freezer still works but the paddle in the bowl does not turn. I took the machine apart and there was a small fuse inside. I am going to see if i can get a new one.
  • Anonymous Apr 10, 2009
    Yes, the motor on my Simac GC 5000 has stopped turning the paddle too. Did replacing the fuse work for you?
5 Suggested Answers
SOURCE: Simac - IL GELATAIO 1600 - The Ice Cream Maker Manual
See http://simac.com.au/index.php?option=com_content&task=view&id=21&Itemid=35 for GC-5000 manuals (one in Italian, with diagram). Not exactly the same thing, but looks pretty similar
Posted on Jan 29, 2009
clyde2j2
  • 137 Answers
SOURCE: need new dasher for il gelataio 800
Try these URLs
www.abtecparts.com---www.marbeck.com---www.smallappliance.com---www.nelsonappliance.com
Posted on Mar 02, 2009
  • 5603 Answers
SOURCE: Simac gelataio magnum plus machine does not get cold or freeze.
If the outer tub does not chill down, then the refrigeration is gone. CHECK that the airflow from the vents is active and free of obstruction.
If the tub starts to chill but the product tub doesn't get cold enough, you may have forgotten to put the Gin or suitable alcohol transfer medium in the outer tub.
Posted on Nov 09, 2009
alicantecoli
  • 21981 Answers
SOURCE: I am trying to repair
some of these machines are just not worth repairing at times as the problem is spare parts ,now if it was a carpagarne or however its spelt then parts are available from italy direct from the factory but this machine i have never heard off ,if you cannot locate parts from the internet then chances are they are not available ,the bearings are not a problem as a auto factor will most likely have them or a timkin agent will have equilivent ,a engineering shop can and should be able to re manufacture parts in stainless for the machine if their willing and able .but i do know these soft ice cream machines cost a arm and a leg and i dont know why
Posted on Nov 30, 2010
SOURCE: I have an old Simac Il Gelataio Super. I believe
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Posted on Jan 20, 2011
What causes the simac il gelataio to quit churning?
If you give the paddle a nudge, will it start ? If so most likely the big capacitor inside the machine. This capacitor will kick start the motor. If it is gone, the motor does not get enough power to get going. It is easy to replace once you have the cover off and should cost around $7.
Jun 30, 2014 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Need repair manual for IL Gelataio 1600 ice cream
Best I can recommend is to go to www.delonghi-accessories.com. It's the site of a US distributor for Delonghi, which is the parent company of Simac, and it lists numbers for support.
You could try www.simac-vetrella.com if you speak Italian; or www.simac.com.au (I think this is a retailers site) might have parts, also.
Good luck.
kmaloy
http://grovebungalow.blogspot.com
Oct 16, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
I need the mixer blade
I need a Mixer Blade for my Simac IL Gelataio
Jul 06, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Parts needed for Simac IL GELATIAO 1600
Try Calling Electra-Craft in New Jersey at 800-223-9370. i have ordered parts for my Il Gelataio 1600. especially the little screw knob that holds down the paddle.
Paul
Aug 03, 2008 | Simac 4070 Gelato Junior 1 Quart Ice Cream...
Il Gelataio SC
For any customer service or problems with your machine Contact (800)223-1898 Mon-Fri. 9-5 (E.S.T.)
Jul 22, 2008 | Simac 4070 Gelato Junior 1 Quart Ice Cream...
Parts
I have a Simac IL 1600 Gelataio Ice Cream Maker Machine I need the top the paddel, top , and screw
Mar 20, 2008 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Simac 4050 Il Gelatao Magnum 1 Quart Ice Cream Maker Logo
578 people viewed this question
Top Simac Ice Cream Makers Experts
Tom Chichester
Are you a Simac Ice Cream Maker Expert? Answer questions, earn points and help others
