Question about Makita 18V LXT Circular Saw
Problem finding blade choices for Makita circular saw
I got a Makita 18v LXT cordless saw for my husband. It comes with one 16T blade (5-3/8 with 5/8 arbor). He needs another blade with more teeth for cutting plywood etc. But Makita doesn't sell any other blades for it on their web site. When I use a search engine to look for blades I get sites with hundreds of blades to wade through. Most have the wrong size arbor. Can anyone recommend a specific blade, that has more teeth for wood cutting, than the factory installed blade?
  • 2 more comments
  • cvwalters Jan 21, 2009
    Thanks tcdchameleon but the arbor is 10 mm and I need a 5/8 arbor.
    rowdy 45176 will see what you come up with.
  • cvwalters Jan 22, 2009
    Rowdy I can't believe that Makita manufactures a saw that only takes one blade. Wouldn't have gotten it if I had known. Will check into the saw repair shop...thanks.
  • cvwalters Jan 26, 2009
    Thanks so much for the effort and time it took to find this out for me. I bought it on Amazon. The saw was exactly as depicted but who could have guessed no blades would be available? We got batteries and charger then from another dealer. I guess we'll keep the saw for limited apps. But I won't recommend it to anyone else!
  • David Ford
    David Ford May 11, 2010
    I am not having any more luck than you but let call a friend who owns a service center and see if he can come up with something for you. I hope to have info on 21 or 22 Jan.
  • 2,176 Answers
OK done some more checking and I believe you are out of luck, but before giving up hope do you have a saw sharpening business in your area?? My friend says that he has sent blades to one in my area and had the center hole bored out to the appropriate arbor hole and the blades run true and from what he tells me it is relatively cheap, so check first and see and then you can buy a blade in the diameter you want and have it bored out. Sorrry I couldn't come up with anything else, I check about 6 diffferent mfrs and they all have the same.
Posted on Jan 21, 2009
  • David Ford
    David Ford Jan 23, 2009
    Last comment on this, called Makita Tech service today and was disassponted with their response to your problem. When did you buy this tool is recently I would try and take back to dealer and explain situation to them and see if you can exchange it for a more common blade size, most tool mfrs that I have worked for and know will do this and chalk it up to customer satisfaction. Sorry I couldn't help further and good luck. Makita is a good tool this is just an odd one
    Problem Solver:
  • 9 Answers
Saw stopped working. changed brushes. still not working.just dead.blade turns ok.not even a click
These are notorious for burning out armatures.
The replacement process is pretty involved, I would not attempt unless you are comfortable.
Remove the brushes
Remove the 3 Screws hold the motor assy to the saw
Remove the screws holding the motor housing together.
Separate the housing and you should be able to see right away if the armature is burnt (many times the windings actually blow apart)
Often when the armature burns out it also melts the brush holder assy - I would recommend replacing it as well.
If the armature appears fine then I would lean toward the switch. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita Bss611 18v Lithion 612" Circular...
Saw stopped working, changed brushes, still will not turn
These are notorious for burning out the armatures. If you are comfortable opening the tool up you can tell very quickly - I have sent a link with the breakdown showing how the tool goes together.
Usually visual inspection is all that is necessary - if the armature is the culprit you will see it is burnt or even blown apart.
If the armature is the problem, most of the time it also damages the brush holder assy & it should be replaced as well.
If the armature is in good shape then your problem is the switch, but my experience would have you check the armature first. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita 18 Volt Bss611 Cordless Circular...
Makita wiring diagrams
Go to makitausa.com. They're pretty good about getting you the info. you need. The contact us tab will get you to their phone number.
Jul 23, 2014 | Makita BUB182Z 18V LXT Li-Ion Cordless...
Bjv180 blade snapped how do i remove it?
Hi
I don't have the actual answer, but this may help you!
http://www.makita.nl/images/files/onderdelen/nl/BJV180-TE.pdf
Just to state the obvious, you have slid the plastic piece to undo the blade holder?
See page 6 of the manual here
http://wiki.makespace.org/images/b/b1/BJV180_manual.pdf
Hope this may help.
If all else fails I would put some oil into the blade holder and try wiggling the holder. Failing that a bit of wire and some fine pliers. Failing that a good blast of air from the aircompressor to try and blast it out.
Good luck
May 25, 2014 | Makita Bjv180 18v Lxt Cordless Jig Saw,...
How come my lithium 18v battery (194205-3) wont fit on my new Makita 6 1/2 circular saw?
I sell & repair the Makita line of tools and the BL1830 (194205-3) battery is designed to fit on Makita's entire line of 18-volt tools. You didn't give the model number of your saw so my best suggestion is to make sure the saw is an 18-volt tool then make sure the tool's and battery's mating surfaces are OK. Try the battery in other tools & try other batteries on the saw. If this doesn't help please respond with the saw's model number or what you found out doing what I've suggested.
Feb 24, 2013 | Makita 194205-3 Bl1830 18V Lion Lxt...
I have changed the armature (windings) on my makita BCS550 18v metal cutting circular saw but now it is going in reverse, any help greatly appriciated.
I believe the motor is a brush style unit (only an educated guess) I would revers the wire going to the armature. Most small brush style motors are polarity sensitive.
Feb 20, 2013 | Makita BCS550 18V Lxt Lithium Ion 5 3/8...
I cannot loosen the bolt that holds the blade on my 7 1/4 Makita circular saw. How do I make the blade stop spinning to loosen it?
they make a blade holder now but usually if you hold the blade against a wood block real tight you can loosen the bold / screw . most warn against over tightening them
Sep 04, 2010 | Makita 18V LXT Circular Saw
SPRING LOCATION FOR BLADE GUARD
go to a store that sells the one you have and look at a new one . some wrap almost around the guard and some don't
May 01, 2010 | Makita 18V LXT Circular Saw
Makita 18V LXT Circular Saw  Logo
209 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
