Sharp copier model AR-M350, error code L6-10 how to repair it?
5 Suggested Answers
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
U2 91 code
This code may clear by simply switching the machine off via its main power switch.
To reset it using a test simulation try the following:
# * C * then type 16 and press your start / copy key. This should reset the U2 code.
The error is a PCU check sum error.
Jan 22, 2014 | Sharp Copier Toner AR-M350 450 AR450NT
Tip
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
on May 17, 2010 | Sharp AR-M350U Copier
Service manual manuals
http://www.smpcshop.com/Sharp-AR-M280N-Sharp-AR-M280U-Sharp-AR-M350-Sharp-AR-M450-U-N-Service-Manual.html
Nov 23, 2013 | Sharp AR-M450N Black & White Copier
Sharp copier repair code F5-02
Here is a list of all Sharp Copier Error Codes
The Sharp AR-M205 is almost 12 years old now. It will be very hard to find parts for that machine unless you can find a low meter on ebay.
You may want to take a look here at some of the current Sharp copier models. It looks like the Sharp MX-M232 replaced this machine.
Oct 29, 2012 | Sharp AR-M205 Copier
I need a windows 7 driver for a Sharp AR-M350 Printer
Hi Ally, It does not appear as though there are any Windows 7 drivers for this Printer. Here is the link for the Vista drivers that you can try. Usually the Windows 7 and Vista drivers are the same.
http://www.sharp-idncservice.com/DesktopModules/SharpDriver/SDdlViewFile.aspx?IDFile=1122&file=Tiger-PS-0708a-2KXPVista.zip&location=D:\index\IdncService\AR-M350-450N\Tiger-PS-0708a-2KXPVista.zip&From=SharpUSA
If the link does not work you can go http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx and select "MFP's and Printers" select your model from the discontinued section, select Microsoft form the Driver Platform and then select Vista.
Thanks Edge.
Jun 27, 2011 | Office Equipment & Supplies
AR-M350 H04-01 ERROR
this is a fuser error H04 01 Heat roller low temperature check the fuser (fixing unit)
Oct 12, 2010 | Sharp AR-M350N Copier
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
Sep 16, 2010 | Sharp AR 163 Copier
U6-03 error on sharp ar-m350... is there a code i can type in to fix it?
Tray 3 is not lifting or lowering properly. There could be a bad lift motor on the tray. The tray could have a bad sensor. Someting is either not moving the tray up and down or the sensors are not detecting the movement.
Remove the paper and the tray, inspect the tray , see if it moves freely, look for something bent or out of place.
U6-03 indicated a tray three lift problem.
Aug 09, 2010 | Sharp AR-M350U Copier
What is kod e7-03on a Sharp ar-m350
laser unit problem.20% clean mirror under copy lamp and white sheet under the glass
May 27, 2010 | Sharp AR-M350N Copier
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
jasbo
jasbo
