Question about Canon imageRUNNER C3200 Copier
GPR-11 toner Hello I have a IRC3200 i was wondering, i have 2 cartridges that are GPR-20 is there a way to trick the IRC3200 into taking this toner? i know you have to take off the front part to fit> However, i tried it and it didnt work. i even tried switching out the chips. any suggestions would be helpful thanks..jeff
  • 168 Answers
Cant do it
Posted on Jan 20, 2009
How do you replace the toner refill cartridge? we can't get it to release from the carrier portion.
Leave the drum/ toner cartridge in the copier. Open the front right access door and rotate the blue hook ring clockwise. Gently pull out the cartridge and reverse the process. You may want to put newspaper below the area so that if toner is spilled it can easily be cleaned up. There are also picture instructions on the toner cartridge box. This uses GPR-10 toner only.
Jun 15, 2011 | Canon imageRUNNER 1310 Copier
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
Hello there! When I print, all documents have a grey streak across it. its very slight but it also looks bad to customers so Im wondering if someone can help me Thank you in advance
Either the toner cartridges, the fuser, or the photodeveloper cartridge are defective, or toner has accumulated in front of the printhead or on the printhead lens.
Replace the color toner cartridge causing the
line. If you still have the problem, replace the fuser and the photodeveloper cartridge. Clean any spilled toner you see in the printer housing near the printhead using a soft, clean
lint-free cloth. Clean the printhead lens.
Clean the printhead lens when you see print quality problems :
1 Turn the printer off.
2 Pull the front door release latch forward and gently lower the front door.
3 Remove all of the toner cartridges one at a time.
4 Open the top door.
5 Remove the photodeveloper cartridge.
6 Pull on the tabs to lift the lens cover.
7 Gently wipe the printhead lens in one direction using a clean, dry lint-free cloth.
8 Push the lens cover down.
9 Align the photodeveloper cartridge with its opening. Gently lower it into place.
10 Push the latches away from each other to lock the photodeveloper cartridge into place.
11 Close the top door.
12 Install all of the toner cartridges.
13 Close the front door.
14 Turn the printer on.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 26, 2011 | Lexmark C510 Laser Printer
To replace the Canon GPR-11 black drum, do you just take the old one out and put the new one in? That is what we did and there is a band of black toner printing on the top of each sheet.
The new toner cartridge snap's into the top of the Hopper > just look on the box on how to install it. Once you have pulled the tab till you can read "STOP" push the slid back in and release the toner cartridge and you are done...... Put the empty cartridge into the "G" file
Oct 01, 2010 | Canon NP 6035 Copier
We have been sent a toner cartridge for our ir3300 but despite directions on the side of the box it does not appear to fit
Canon toner type GPR-6, correct? Open the front cover. Rotate lever to release toner/developer unit. Pull the unit straight out until it stops. Insert new cartridge to line up with top of toner/developer unit at a slight angle (lower at back) Once the cartridge stops at the rear (I would hold the toner/developer unit with one hand while inserting the cartridge) then lower the front end of toner cartridge down on top of the unit.....press down until toner cart. clicks into place. You will know because a tab pops out the front with clear plastic attatched. Pull the tab to release toner and release top of toner/dev. unit. Keep pulling until it stops. Wait about 7 seconds, now tap on toner cartridge to release all loose toner (don't forget to shake toner before opening) After about 15 seconds, toner should be fully loaded. Now push top cover of toner/developer unit back in until it latches, you will know because the empty cartridge releases from the unit. Now remove empty cartridge, reinsert unit, turn latch handle and close front cover.
Oct 07, 2009 | Canon Office Equipment & Supplies
We replaced the toner and it is still saying "toner life end replace toner cartridge." and we can't get it to print or fax or copy
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 23, 2009 | Brother MFC 7840W Printer
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
Canon Image Runner C3200 GPR 11 Drum Units
error code eo-20 on canon pc740 without replacing drum/toner unit
Nov 05, 2007 | Office Equipment & Supplies
Canon imageRUNNER C3200 Copier Logo
64 people viewed this question
old marine
old marine
