Question about Exercise & Fitness
I have a problem with my Powerjog treadmill it will not work as the display is showing a fault on the incline and belt needs lubricating
SOURCE: I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Posted on May 18, 2009
SOURCE: I have a Lifestyler 8.0 Treadmill. It keeps
Use a good silicone Spray under the belt for every 10 hours of use
Posted on Apr 29, 2010
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
Belt feels like it slips when I'm walking
If the belt is worn on the underside you will definitely want to replace the belt. The link at the bottom will take you to a video on how to use a liquid lube on your treadmill. Lubricating the belt/deck every 30 days will prolong the life of the belt and the deck.
The friction caused by excessive wear on the belt and/or the deck can cause a high amp draw and make the drive motor work harder than it's designed to.
How to Lubricate Treadmill Using Liquid Lube Video
Jan 17, 2013 | Precor 9.21 Treadmill
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Jun 13, 2010 | Spirit Fitness Z500 Treadmill
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
I have an error message on my powerjog treadmill
jx 100 powerjog displaying self diagnostic error-how do you find what the error is
Mar 22, 2010 | Exercise & Fitness
Kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Mar 29, 2009 | Kettler Exercise & Fitness
Exercise & Fitness Logo
18 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
