Question about Agri-Fab Agri - Fab Snow Blower - 42"
Toro 826 le snowthrower
When you engage both the auger lever and the traction lever, the traction lever is supposed to lock the auger lever down, freeing the right hand. My auger lever does not stay down. How can I fix this?
  • sfl11 Feb 04, 2009
    I have a Toro 10/28 and I used it twice and now the traction lever will not lock down the Auger lever.Is this just a problem with Toro?
  • Alex
    Alex Feb 10, 2015
    My TOYO power max HD 926 has the same problem. Traction level does not lock the auger level down. How do I fix it?
    Top Expert:
  • Agri-Fab Master
  • 2,570 Answers
I am not sure of the locking mechanics, or what may be worn and requiring replacement.
I recommend that you contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Downloadable Manuals
I trust this information proves useful.
Posted on Feb 14, 2018
3 Suggested Answers
  • 70 Answers
SOURCE: where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Posted on Dec 22, 2008
  • 2468 Answers
SOURCE: I have a 5/22 2 stage MTD snowthrower and from
your shear pin(s) are broken on that side they will look o.k. but are snapped off inside drive them out with a large nail or center-punch,don't use a regular bolt to replace the shear pin as they will fit,because if it gets plugged again the gearbox will be your next expensive shear pin to replace
Posted on Feb 24, 2010
I have a toro 826 snowblower and i cant get the thing to start there is no primmer bulb i dont know if the choke lever goes down to start?
https://www.toro.com/en/homeowner/snow-blowers/power-max-826-oe-37772
Click on parts and manuals then select the year that it was made and then you can download the operators manual.
The most common cause of failure to start is bad gasoline, Gasoline cannot be left in the fuel tank without a stabilizer added to it. It goes bad after about 1 month.
Nov 20, 2016 | Garden
How to replace the traction spring on a toro 521 Snowthrower
Contact Toro for a Schematic unless you have one in your possession. They usually come with the units manual and instructions.
Dec 28, 2014 | Toro Garden
I'm not asking about a leaf blower It's a toro snowthrower model # 38600. what's the proper way to remove and replace the impeller blades?
You have to disassemble the entire front of the snow blower. This means removing the snow shroud, auger bits and then getting to the impeller blades. I did it once and it took me about 1 1/2 hrs to complete.
Dec 14, 2014 | Toro Garden
Which oil to use for toro model 826 le
Hello, Here is the oil and i am putting the website for you to have the specs for the engine on it too. The oil to use is 26 oz. (.8l) 5w-30 or 10w / API SH or higher. Toro
Dec 11, 2014 | Toro Garden
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Dec 17, 2013 | Honda Snowblower Cover Silver Hs928,...
How to adjust the Toro 826 snow thrower
Belts will have spring tension on the idler pulleys.
Both traction and auger control cables will also have cable length adjustments to cause the travel of levers or idler pulleys to tighten belts. Adjustments are commonly located under the control panel/levers.
Dec 03, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Agri-Fab Agri - Fab Snow Blower - 42" Logo
449 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
