Question about Panasonic UF770 Laser Printer
UF-770 error "no recording paper in try no. 2"
I can not receive faxes because of this issue. I have opened all of the doors and cleared all paper jams. I also filled both paper trays but the error wont clear.
    Genius:
  • 2,120 Answers
Can you hear the cassette tray POP when you slide it in?
Maybe the paper is not lifting up..
Posted on Feb 06, 2009
My fax machine has an error code "Check Paper", and I cannot clear it and my machine will not work.
Solution :
1. Cheak your backside door and cheak there can be found some broken paper.
2. Poner can be the problem for ......
3. Heat paper broken or the roller jam. if not solve send me ur model no.
Jul 31, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Uf-770 how do you stop the received fax and delete it? 900 page fax that I need to delete
Open the toner door
Turn the machine off
Open the document feeder
While holding down the pointed switch by the skinny glass turn the machine on ...hold down switch until you hear a beep...close doc feeder
Clean out any jammed paper by opening the toner door
Scroll down to ALL JOB CLEAR
press SET
wait for the machine to initialize
Jun 10, 2010 | Panasonic Office Equipment & Supplies
Battery for Panasonic UF 770
You will need a technician. They may not be available anymore.
Sep 21, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
I have a Panafax 770 when sending fax it reduces the recived fax
Open up the document feeder and make sure of the switches is not trapped in the down position.
May 18, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Error code 634 on Panafax UF-770
The receiving fax machine is turned off or not functioning. Try calling your cell phone.
Do you have a DSL phone line?
Nov 21, 2008 | Office Equipment & Supplies
Panafax UF 770
What happens when you try to send?
Nov 07, 2008 | Panasonic Panafax UF-333 Plain Paper...
Change setting to not receive faxes at this station
Function 64 set
look for manual mode on the print out
set to manual through sim Function 74 set
Aug 11, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Clearing Memory
go into service mode then into ram initialize and do all job clear. yo avoid this happening again set "inc. file save to invalid"
Mar 04, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic UF770 Laser Printer Logo
87 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
