Question about WMF Coffee Makers & Espresso Machines
WMF Presto cafe latte
When I try to make a cafe latte the machine ads to much milk, It start by adding milk then it adds milk again and then it adds the coffe.
SOURCE: I have a new Nespresso Machine from DeLonghi. I
screen is flashing blue (craig player 4gb mp4
Posted on Dec 06, 2009
  • 18 Answers
SOURCE: i just got a eam
There is a blockage in the steam/ hot water circuit. By trying repeatedly to use these functions the steam boiler has now overheated and blown a thermal fuse ( thats why the alarm is displayed and now the infuser is in the wrong position for removal). If this machine is under warranty you should return it as soon as possible. If no warranty and you are a handy person (genuinely) then post again and i can help you fix it. No Good luck Rick.
Posted on Dec 12, 2010
mikey270
  • 26 Answers
SOURCE: I have a WMF Presto coffee machine and when I
You have to have a lap top and software to repair! The only way to turn off the boot manager is to use the software that you can get from WMF! Try giving them a call if you don't have a tech in the area. 954-583-2269, good luck
mikey@espressomachineexperts.com
Posted on Feb 28, 2011
SOURCE: I have a new Krups XP 5240 machine. The
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Leni
Posted on Nov 08, 2011
katarzyna_ko
SOURCE: fault code 167 on my
Did You Solve problebm? What does it mean"luggers"?
Posted on May 23, 2012
My caffitaly S 23 does not dispense hot Millikan after the coffee has dispensed. Just hot steam and a little bubbly hot water. I have cleaned it it and will dispense milk and the next cup doesn't.
First; I am NOT a Caffitaly repairman. Though I have worked on mini espresso machines. Sputtering and/or poor steam is an indication that your brewer is not up to brewing temperature.
** Most of these home machines have a very small boiler or tank. They are designed to produce hot water and sometimes steam to brew a small 'European' espresso. Here in the USA we like our coffee weaker and with lots of 'other' things mixed in. The 'Americano' is the same amount of coffee but with a lot of hot water added. This amount will tax the small boiler to it's limits. Top it off with a grande latte would be probably be beyond it's ability to completely froth/heat this amount of milk. When you order a Latte from a Barista you will note that it takes a while to froth a Pitcher of cold milk. They are using a large espresso machine and probably pulling a double shot of espresso. To make a similar drink with any home machine requires doing everything 'double' or twice brew. (3 times?) You will need to check the 'ready' light to make sure the brewer is up to heat prior to brewing your next cup.
** Suggest brewing a regular size or 1/2 a mug of coffee-latte then come back again later for another fresh hot cup.
Aloha! ukeboy57
Dec 21, 2017 | Coffee Makers & Espresso Machines
Tip
How to display your banners in handy cafe- internet cafe manager
its very easy to display ads and banners in internet cafe.You can make extra revenue from it. Here is the tips to add banners in handy cafe server and it will show when a user log in to the client computers. <br /> <b>Login</b> to <b>handy cafe server</b> using <b>user name and password</b> <br /> <br /> <br /> Click on <b>Options</b> Tab <br /> <br /> <img src="shabype.JPG" /><br /> <br /> <br /> <br /> Select <b>Banners</b> from the list and Click on <b>New</b> <br /> <br /> <br /> <img src="shabype_0.JPG" /><br /> <br /> <br /> <br /> <b>Add/Edit Banner</b> will pop up.Click on <b>Add button</b> <br /> <br /> <br /> <img src="shabype_1.JPG" /><br /> <br /> <br /> <br /> <b>Browse</b> for the banner file ( must be a video file) <br /> <br /> <br /> <img src="shabype_2.JPG" /><br /> <br /> <br /> <br /> Click on <b>Open</b> <br /> <br /> <br /> <img src="shabype_3.JPG" /><br /> <br /> <br /> You can see the attachments. Click on <b>OK</b> and then Click on <b>OK</b> again. <br /> Now you can login to any client system and see the ad displaying .You can set <b>time period </b>as your wish.
on Dec 28, 2010 | Computers & Internet
Are there different types of espresso coffee?
The classic form of espresso is a small shot (2-3oz) of pressure brewed coffee made using about 1tblspn of finely ground coffee. There are several ways in which this original format has been altered to come up with various types of espresso coffee drinks. Here is a short list of some of the more popular varieties:
Americano - espresso with hot water added to dilute the strength
Macchiato - espresso shot with a small amount of frothed milk on top
Corretto - espresso mixed with a bit of alcohol
Cappuccino - a shot of espresso topped with 1/3 steamed milk and 1/3 frothed milk
Mocha - a latte with chocolate powder/chocolate sauce added
If you would like to know more about espresso, please visit the link below.
http://www.1stincoffee.com/what-is-espresso.htm
Feb 07, 2013 | Wine & Spirits
Delonghi Lattissima EN 660CW milk frother not frothing
I don't know why my answer posted in the comments section, so here it is in the proper area.
I had the same problem and was ready to send it in for repairs, but I talked to a great guy at Nespresso who helped me fix it myself. The problem was when I pushed the latte button, it would only froth milk for a second or two and then the espresso would start pouring. It basically refused to make a latte. Here's the things he had me do:
1) Descale immediately. I have an older machine, and descaling once a year does NOT cut it. He told me descaling every 5 months at the bare minimum, if your machine is not having any problems at all. Descaling is usually the main problem for lack of froth. I descaled and it seemed like the machine was working better almost immediately. I also ran 4 - 5 tanks of water through the hot water spout and the main espresso part (but mostly this is because it seems to take this much flushing to get the smell of the descaling solution out).
2) Reset your machine to factory settings. I have a classic Lattissima, so this is how you do it on that machine. Turn the machine on and wait until the drink buttons are steady (espresso and hot water buttons are no longer blinking to warm up). Then press and HOLD the power button until the espresso and hot water buttons BLINK THREE TIMES. Then they'll go back to steady again. You're now back to factory settings.
I did notice that I started having the trouble after moving the machine, so I'm not sure which of the above solved the problem. The main thing is it worked and I'm back to yummy lattes!
Jan 09, 2012 | DeLonghi Nespresso EN660 Espresso Machine
I just got a eam 3500 machine. On first time instructions, no hot water would come out. produces a good cup of coffee though. When i've tried to froth milk for a latte, no milk is added to coffee. I have...
Dec 10, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for...
Hope this helps,
Leni
Nov 06, 2010 | Krups Cappuccino/Espresso Maker -...
Steamed milk
I've just taken delivery of an S9 and my lattes were lukewarm too. What you have to do is move the dial on the steamer to the 3 o clock position. See http://cdn2.libsyn.com/coffeegeek/jura_frothxpress.mov?nvb=20081110133816&nva=20081111133816&t=018ee7ad85c33f422c6a5 . Latte I just made was piping hot. If that doesn't fix it, try the Products settings. If still lukewarm I think you should contact your dealer, maybe you have a duff machine.
Oct 18, 2008 | Jura Capresso Impressa X90 Espresso...
Coffee Makers & Espresso Machines Logo
Top WMF Coffee Makers & Espresso Machines Experts
David Burbee
David Burbee
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a WMF Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
