Question about Ovens
How to change light bulb in smeg electric oven spa 42016
  • 1462 Answers
SOURCE: light bulb
for most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
Posted on May 07, 2007
tborn6
  • 700 Answers
SOURCE: Replacing thermocouple on smeg oven
Look at the bottom of the oven and see if you can remove the panel, if its all one piece then take out broiler pan and look inside to see if you acan get to the pilot burner. Good Luck
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: Can't remove the oven light cover to change the bulb
clean it with wd40
Posted on Jun 30, 2009
heatman101
  • 43501 Answers
SOURCE: Smeg f67 electric oven not reaching temp on conventional setting
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 23, 2010
SOURCE: oven will not switch on
My Smeg oven will not work either. All I get is an "A" on the display, the clock has disappeared and as a result the oven won't come on. I see from other postings here I can bypass the clock so that the oven works again - can anyone advise how I do this?
Posted on Aug 05, 2010
Which of the five small buttons do I press to make the oven function? start
Ok! Until the clock is set the oven will not work, I will describe the 5 buttons as numbers from the left!
Press and hold the 3rd button for 2seconds, then press the 4th or 5th buttons to set the clock to the correct time, then press the 3rd button to set!
Jan 01, 2015 | Smeg Ovens
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 13, 2013 | Smeg Ovens
Smeg cooker SPA 42016 oven will not heat up although the fan is working and the oven light is on
This happened with my 42016 single oven. It was the element. They can be bought online and are easy to fit.
Mar 17, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Manual for Smeg SpA42016
SpA 42016 is Smeg's postcode in Italy! Model number will be on same lable. Mod:
Jun 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Light bulb
May 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
