Champion shredder WQ120D will not shut down after shredding but continues to run . must move to center position to shut down
  • rddawg1771 Feb 18, 2009
    Ours will not turn off either. We have tried the "air blowing" to noavail. We have tried the "cleaning sheets" and "paper with oil", still to noavail.
If you look at the blades, some are likely bent (probably the middle ones) causing the machine to not drop the clippings which makes it think that there's paper to be shredded. It's a common problem with this shredder and there's no fixing it because the company doesn't offer replacement parts. The shredder is an overpriced piece of junk. I bought mine at Walmart but our local store doesn't even carry them anymore because of all of the returns they've had.
Posted on Aug 31, 2009
    Genius:
  • 2,120 Answers
Blow some compessed air down into the shredder slot.
Posted on Jan 24, 2009
Why wont my staples titanium shredder continuously shred?
Not giving a model number, it's hard to say. But quite probably after use for 20 mins, the machine starts getting hot, and then it shuts down while the machine cools down.
I had the same issue with a shredder of mine. It prevents the machine burning itself out.
If you want one that just keeps going and going without heat issues, you have to pay more for a better shredder. Unfortunately.
Jul 30, 2014 | Industrial Paper Shredders Office...
My handyman took apart my Champion WQ120D paper shredder to remove the checkbook that was jammed. But it looked to him as if some transisters were burned. Once together again, minus a plastic shim at the...
It sounds like the shredder overloaded when you tried to shred the checkbook. If there is a smell of burned electronics this probably means that the shreader is dead. The plastic shims have nothing to do with the turning on and off of the shredder. Next time buy a shredder that is rated for at least 7-8 sheets, indicating a more powerful motor and sturdier blades. If the current shredder was repairable, it would be cost prohibitive over buying a replacement. Sorry for the bad news.
Sep 09, 2011 | Office Equipment & Supplies
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Apr 07, 2011 | Black & Decker Garden
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Paper shredder jammed - won't turn on anymore. Not sure how to clear jam. Champion WQ120D shredder.
there should be access to manually move the rollers may be with an allen wrench
Apr 21, 2010 | Office Equipment & Supplies
Just does not shrep the paper and smell like it is burning
Buy a commercial model the next time. It will cost you a few hundred, but worth it. Fellowes is a good brand with great support.
Jun 19, 2009 | Office Equipment & Supplies
Shredder knive are all bent up
Heres a few sites that have gears and parts another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
May 23, 2009 | OfficeMax 0M96431 Shredder
My champion shredder wq120d does not work.The machine was working fine, but when i emptied the container and tried to shred papers the red light turns and does not work. How can the problem be fixed?
It sounds like bin full flapper / switch isn't working Move the flapper back anfd forth to hear the switch clicking.
Also do the same thing to the front door.
Oct 12, 2008 | Office Equipment & Supplies
830 people viewed this question
k24674
