Question about Jetway Mini-TOP HBJC600C99-52W-BW Intel Atom D525 CPU NM10 Next-Generation NVIDIA ION with dedicated... (HBJC600C9952WBW) Barebone
Jetway mini-top running hot
My Jetway Mini-top is running hot and shutting down every few minutes. The combination CPU, Chipset, Video cooling fan is running at max speed put it still gets over max temp and shuts down. I've looked at and verified that the componnents and heat sink are making secure contact and still it is unusable in this condition. Any help or suggestions would be appreciated.
2 Suggested Answers
jcavanagh617
SOURCE: Where is the CMOS reset
I am not sure you have the exact model I do, but the battery is on the underside of the motherboard - you must undo the four silver screws holding the board down, and also two screws to remove the front plate. Pull the board up and out, and you will see the battery underneath.
Posted on Nov 19, 2011
Why does 2000 s40 volvo turbo runs hot and the fan stays on after shut off
fans are designed to run on after you shut engine down as engine temperature rise after switching off . running hot could be caused by the top hose having gone soft when you rev the engine the water pump sucks the hose flat stopping the coolant flow or the radiator is blocked and need flushing out
Sep 16, 2014 | 2000 Volvo S40
TOO HIGH TEMPERATURES AT MY LAPTOP ACER ASPIRE 5735Z
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 01, 2012 | Acer Aspire Computers & Internet
Ok i read some forums on the web about the amd am2 5800+ processors and it says nothin about them overheatin.. so down on the forum it said that when the cpu shut off from gettin to hot to feel the...
try this, open case then plug off processor cooling fan, then plug off processor, clean it, then plug on again the processor and cooling fan, if need take more fan on your pc then turn it on, if still like that it mean you must change your processor
Jan 23, 2011 | Abit Fatal1ty AN9 32X Motherboard
Games slow down after 5 minutes and then speed right back up for 5 minutes. rinse repeat
Try Game Booster software. Its Freeware. You can download it from http://www.iobit.com/gamebooster.html
P.S-Plz don't forget to rate me.
Oct 15, 2009 | MSI GX630-028US Notebook
Sudden shut down
You need to clean it out with some compressed air.
Make sure the laptop is turned off of course.
If you still have heating issues, then you'll need to take it apart and put a new layer of thermal paste on the heat sink / cpu.
Best of luck!
Jun 18, 2009 | Computers & Internet
Overclocking on this board with an E2180?
When the CPU overheats it shuts down especially if you overclock it.
Did you put any heatsink compound between the CPU and the heatsink (this aids heat transfer from the CPU to the heatsink/fan)?
Your BIOS may have a setting that can adjust the CPU fan speed/temperature.
You can install additional fan/s in the case to draw more air into the computer case.
To further cool the CPU, you might have to install a better and more efficient cooling heatsink/device/fan on the CPU.
Feb 10, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Samsung smh7150 shuts down after a few minutes.
If the mag overheats because its not being cooled it will shut down until its cool.
If the fan is turning slow you can try oiling it but it likely needs replacing.
Another thing that causes this is that the exaust port is blocked because its upagainst the wall and the hot air can not escape.
Jan 12, 2009 | Samsung SMH7178STD Microwave Oven
Upgrade of ram
Your board Support 168-pin SDRAM DIMM and 184-pin DDR DIMM (Can't Use DIMM & DDR SDRAM memory Together).
I would run the 184-pin DDR. Supports PC1600/PC2100 DDR DRAM up to 2BG Max. Since you have four memory slots 2x512mb of DDR PC2100 = 1GB would be plenty. You will notice programs load faster & games run smoother. Personally, 2Gb. may help but you will not see the difference. To see a difference it is not all about memory. Mb bus speed, CPU, chipset & speed of video memory all play a part with regards to Pc overall speed. You can download your manual here.: http://www.jetway.com.tw/oldweb/evisn/download/manual/index1.htm
You can download the specs of your board here.:
http://www.jetway.com.tw/oldweb/evisn/product/amd/v266b/v266b.htm
And below is a link for some good ram.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=302039&CatId=548
This should all help you decide, best wishes!
Please vote.....
Jan 23, 2008 | Jetway V266B Motherboard
Jetway Mini-TOP HBJC600C99-52W-BW Intel Atom D525 CPU NM10 Next-Generation NVIDIA ION with dedicated... (HBJC600C9952WBW) Barebone Logo
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
