Question about HP LaserJet 1022n Printer
HP 1022n printing an extra, blank page with every print job
I have checked all the settings on my printer, and cannot see anything that will fix this. It is on a network, so I don't know if this has something to do with the print spooler, but I have asked around and it seems mine is the only one that does this.
  • Anonymous Mar 03, 2009
    Have a laserjet 1100 and print job prints a blank sheet after every job.
jaylex
  • 417 Answers
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Posted on Jan 28, 2008
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
agnelkj
  • 210 Answers
SOURCE: prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Posted on Mar 17, 2008
JackHeath
  • 1049 Answers
SOURCE: extra blank page on ricoch printer
There could be a couple reasons...
  1. "Separator page" or "cover page" options could be enabled. The easiest way to find this option is to print a menu map from your machine. These are managed from the configuration page on the printer display
  2. Your printing from a terminal application, no fix...the terminal apps often send a (page break/ carriage return) at the end of jobs to make sure the page is printed and not held in queue.
  3. Check your settings in Office and print setup window - Word, Excel, etc. all have a "Seperator Page" and "Cover Page" options as well.
Hope this helps.
Posted on Jul 24, 2008
toddg
  • 171 Answers
SOURCE: One extra blank page coming out for each page actually printed
    1. Open Printers and Faxes .
    1. Windows XP: Click Start , and then click Printers and Faxes .
    • Windows Vista: Click the Start icon (c01319360.gif ), click Control Panel , and then double-click Printers and Faxes .
    • Windows 2000: Click Start , click Control Panel , and then double-click Printers and Faxes .
    1. Right-click your product, and then click Properties .
    2. In the Properties dialog box, click the Advanced tab. Figure 1: Advanced tab in Properties dialog box 41c9c35.gif
    3. Click the Separator Page... button. The Separator Page dialog box opens. Figure 2: Separator Page dialog box
    4. bb32f03.gifDelete all templates listed in the Separator Page box, and then click OK .
    1. If you deleted any templates, click Apply , and then click OK . If you did not delete any templates, click OK .
    NOTE: The Separator Page function is not related to any network function. To disable the separator page on a network, contact your network administrator or vendor.
  • Posted on Oct 07, 2008
    Hp laserJet 1022n printing multiple copies when copies are set to 1
    Had this same problem found a working solution here http://www.tomshardware.com/forum/59912-3-1022n-printer-stop-printing.
    Just disable bidirectional support in the printer properties worked for me
    Jan 06, 2012 | HP LaserJet 1022n Printer
    I'm printing labels on my printer. After each run, the printer prints out an hp advertisement page for buying supplies, etc. Almost like a test page. How can I delete this annoying and wasteful...
    Try this:
    But first print a configuration report.(contain IP address)
    Configuration Report
    Release GO after LED begins blinking.
    Now:
    Reset the factory default settings (cold reset)
    Turning on the printer while pressing the GO and CANCEL JOB buttons restores the factory default settings.
    1 Turn off the printer.
    2 Press and hold the GO and CANCEL JOB buttons.
    3 Turn the printer on and continue to press and hold the buttons until all three LEDs are blinking.
    4 Release the buttons.
    Jul 13, 2011 | HP LaserJet 1022n Printer
    Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
    Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
    Nov 25, 2010 | HP LaserJet 1022n Printer
    Prints out blank pages
    if it doesn't print anything, there is a problem with the ink cartridges, if it just prints extra blank pages, you need to verify the printer settings have the correct page settings, and that your word processor doesn't add extra pages to your documents.
    Aug 16, 2010 | HP Officejet 7130 All-In-One InkJet...
    Printer Not Woking In Network
    1. check that not any firewall or antivirus software blocking your printer.
    2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
    have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
    Jul 03, 2009 | HP LaserJet 1022 Printer
    Extra blank sheet of paper between printed pages
    Check your print settings, it is possible that you enable page seporator in the settings.
    Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
    HP LaserJet 1022 Printing Blank Pages
    Aug 08, 2008 | HP LaserJet 1022 Printer
    Extra blank page on ricoch printer
    Hope this helps.
    Jul 16, 2008 | Ricoh Aficio CL3500N Laser Printer
    HP 5550 Print issue
    When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
    Jun 20, 2007 | HP DeskJet 5550 InkJet Printer
    HP LaserJet 1022n Printer Logo
    236 people viewed this question
    Seeker5211
    Seeker5211
