Question about Sewing Machines
How to wind bobbin Pfaff 1040 - Sewing Machines
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
  • 10 Answers
SOURCE: Automatic bobbin winder does not stop when bobbin is full
Simply loosen the screw on the bobbin winder stop, no more than 1 full turn or you will drop the backing nut will fall down into your machine, move the bobbin winder stop slightly to the left then tighten the screw and see if that works. you may have to repeat this step several times until you find the right spot to stop the bobbin at the correct point.
Posted on Jun 30, 2009
  • 632 Answers
SOURCE: needle does not move
lower your needle with the presser bar behind the machine. you're in bobbin winding mode when it's at 11 oclock when you look from behind and 2 oclock facing front of machine.
Posted on Sep 05, 2009
  • 1116 Answers
SOURCE: My Pfaff expressions 4.0 says Remove thread jam
Open the needle plate and check this area for an obstruction.
Refer to the manual for how to clean this area so you get everything back in place.
Posted on Mar 20, 2010
  • 1116 Answers
SOURCE: I have a 1953 pfaff 130, and the wheel will wind
If this machine has a center knob on the hand wheel, this has to be tightened for the needle to work.
Posted on Mar 23, 2010
Trying to wind bobbin on my pfaff sewing machine but the bobbin doesn't tur
Hello Kathy
Make sure that:
1. The correct bobbin is being used ... make sure that the bobbin is the one specified for your machine.
2. Make sure that the bobbin is pushed all the way down on the bobbin winding spindle.
3. Make sure that the bobbin winder is engaged ... pushed over for winding.
4. Make sure that the thread is not tightly wound around something preventing it from advancing onto the bobbin.
5. Refer to page 18 of the Manual. If you need one, it is available for free at:
PFAFF tiptronic 6232 Instruction Manual Page 22
May this get you back to sewing very quickly. Please give me a thumbs up if this is helpful, otherwise send me more information.
Sewingirl/
Aug 17, 2017 | PfaFF Sewing Machines
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
How to thread bobbin 451 Pfaff
Having difficulty even locating a photo of the 451. Assuming this is an older model, perhaps this manual will help. It says its also for the 551, so perhaps the model is close enough that it will help you with your machine:
Pfaff 551 Manual pages 1 viewing
If you are unable to figure out the bobbin winder, you may be able to use a standalone bobbin winder (one brand is called Sidewinder) from the fabric store. They run ~$25-30. Just be sure to bring a bobbin with you to check the fit.
vintage sewing machine bobbin winding Google Search
How to Wind Bobbin and Thread Bobbin Case for Vintage Singer Featherweight...
Jul 14, 2016 | PfaFF Sewing Machines
My bobbin winds unevenly, there is always more thread at the bottom of it than there is at the top. Neither switching to the original pfaff bobbin nor either spool position works.
I always use my finger to guide the thread as the bobbin is winding,the bobbin shouldn't be moving around in the metalcase probably needs tightened.
Aug 29, 2015 | PfaFF Sewing Machines
I am unable to disengage the sewing action on my Pfaff 1473CD to wind the bobbin. Will it damage my machine to wind the bobbin with the sewing action engaged?
one of the sewing machines I had once, did that, I could still wind a bobbin though. you might think about getting one of those machines that just winds bobbin.
Jun 20, 2015 | PfaFF Sewing Machines
How to wind the bobbin on a pfaff 1475cd
here is a link for a manual--it should have the information in it that you need
Pfaff 1475 Creative CD Instruction Manual
Dec 17, 2014 | PfaFF Sewing Machines
How do I engage the bobbin winding gear for Pfaff 7570?
To disengage the needle while winding a bobbin do the following: the handwheel on the right end of the machine has an inner knob. hold the outer rim of the handwheel stationary as you rotate the inner knob counterclockwise. Also make sure the bobbin winding peg is pushed over to the right and the bobbin is seated on the peg.
Jul 27, 2014 | PfaFF Creative 7570
Bobbin Winding
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Sewing Machines Logo
97 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
