Question about Delta 31 - 255X X5 18'' x 36'' Drum Sander
New belts on drum sander shear off inside clip
I have a delta 18x36 Drum Sander (31-250) Everytime I put a new belt on the drum it rips off within a few passes. The belt cuts itself off clean where the belt come out of the clamp that holds it in place. Part C in Figure 35 on page 14 of the manual. It happens over an over again. I go though a belt or two, then I usually get one that holds up for a while. When that one wears out I'm back to destorying belts again. I can't figure it out.
  • 2 more comments
  • Anonymous Feb 12, 2009
    I had the same problem when I tried to use cloth-backed rolls that I cut to size.I found that they don't hold up like the Oxide strips. also, make sure that you wrap the strips TIGHTLY, especially at the clamps. if you look, you'll see the strips begin to "rise" at the clamps, as centrificle force moves the clamp.
    but mostly, use stiff paper...I've broke too many brand new cloth -backs to use 'em again.
  • Anonymous Mar 11, 2009
    I have the same prolbem with my 31-250 model and I called Delta and they said that was a problem with that particular model, so what do we do , I tried the oxide paper but the same thing......any help out there...
  • Steven Jaynes
    Steven Jaynes May 24, 2009
    Does it seem to matter which way the arrows on the paper point. Are they supposed to point in the direction of rotation or direction of wrap? Hmmm... maybe they are the same. I have to go look again...
    Steve J
  • cutterboards May 11, 2010
    I have a model 31-255x not a 250. I also buy Klingspor 2" wide strips for my machine. They are AL oxide with cloth back and pretty tough. If the belt sticks out beyond the end of the drum, just cut it off flush. It must be catching on something. Make sure that the belt is shooved down in the clamps on the ends and wrapped tight around the drum. I have even trimmed some of the oxide strip along the angled end so that it fits better and doesn't overlap. These belts will have slight variations in length.
  • 32 Answers
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
Posted on Jul 18, 2009
  • slivermetimb Oct 16, 2010
    I have had my Delta 31-250 since 1999. I developed the same problem of the end of the roll slipping out of the spring. So I started using duct tape on the end and that helped. But the other thing I did"nt realize is that the part on the clip is made out of spring metal. After extensive use it will crack and become more flimsy therefore not holding the cloth sandpaper unless you get it just right. Then it will eventually not hold at all.Had to take a hammer and screwdriver to pop the pin out that holds it. now looking for a replacement.
I'd like to download a manual for the Delta 1" Belt/5" Disc Sander I just picked up at a yard sale. I can't seem to find one. Thanks.
you might try going to dewaltservicenet.com and typing in your model number in the middle of the page towards the bottom under need a manual. If not let me know and I will try and locate another source for you.
Oct 03, 2010 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
31-255-x need brushes for belt drive motor cant find on internet any recomendations?
Go to toolpartsdirect.com they have your sander listed and all parts that are available for it.
Oct 12, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Oct 04, 2009 | Tools & Hardware - Others
User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Jul 20, 2009 | Tools & Hardware - Others
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Porter Cable 352V belt sander eats belts
I've never had any particular problems with norton belts. All belts will require some adjustment as they wear in,however.
Try this: Put a new belt on, turn the sander upside down and rest it on the front handle. Get a good grip on the rear handle and turn it on while you use your other hand to turn the tracking adjustment. Just center the belt on the drum. I don't know what the manual tells you to do, but that's what matters, that the belt rides across the platen without hanging out loose in space or running up against the housing of the machine. If it does ride in against the housing, and you don't track it away, eventually you'll have a groove worn right through the side of the machine.
If you try this, and it still doesn't work, make sure the drums are secure and look right. Is it possible the machine was dropped and the drum bent? If so, parts will have to be replaced.
The only other cause I can imagine is that there is some kind of something jammed inside the housing that is protruding into the belt pathway that they're getting caught on, but that seems unlikely. Check anyway. Look with a flashlight.
There are better belts available than Norton, but they should work.
Some belts have an arrow on the inside of the belt indicating the direction of travel. Make sure if yours does, that you put it on that way. I try to install them so the joint will tend to ride up over the work instead of the work tending to want to tear the joint apart, but this is not always obvious, depending on the mfr.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Oct 13, 2008 | Porter Cable 3" x 21" Electronic Variable...
Delta 31 - 255X X5 18'' x 36'' Drum Sander Logo
359 people viewed this question
Top Delta Tools & Hardware - Others Experts
John Trevino
Andrew Taylor
Andrew Taylor
sonic boom...
sonic boom...
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
