Question about GE JVM1320 Microwave Oven
Loud Pop sound and now buzzing sound and odor
The power to the microwave still works. When you use the microwave it makes a clicking sound over and over and also a bad odor. Model is Sanyo Carousel R-1480. Do you know the cause and approx. how much it would be to fix? Also, would you recommend purchasing a new microwave instead of fixing?
    Problem Solver:
  • 14 Answers
The gear motor and the antenna bearing is defective let it be replaced by technicians near you.these parts comprises maybe 5% of the total value of your unit so I recommend you to let it be repaired
Posted on Mar 31, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Jvm1790sk01 GE Microwave Broken - Manufactured Aug 2005. Working fine until tonight. Loud vibrating humming sound coming from Right Side and Burning Odor... No heating on high power. Just burning odor. ...
Sounds like you Magnetron has failed. The only way to repair this is to replace the part. Some microwaves have an extended warranty on this part. Check your manual and Call GE for service if it does. If the warranty has expired you might as well buy a new microwave unless you are very attached to this one. Hope this helps
Sep 01, 2011 | Microwave Ovens
Microwave makes a loud buzzing noise and emits a burning plastic smell
This indicates the magnetron has failed, buzzing sound and odor are classic symptoms. It is cheaper to replace than have it repaired.
Apr 03, 2011 | Kenmore Microwave Ovens
My microwave makes a loud buzzing sound
Magnitron is going out. Suggest discarding microwave it will possibly go completely out in the near future. Good luck hope this helped
Dave
Nov 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Microwave making loud buzzing sound when operated, sounds like something is about to pop.
could be several possible components at fault. how old is it ? does the unit heat ? if so, could be a hi voltage diode, or a hi voltage tranformer. (older frigidaire m'w's had trans. that would crackle and "arc" when bad) it is not the mag though, it wouldn't heat if so.
Sep 25, 2009 | Microwave Ovens
My over the stove microwave will run however no heat. Popcorn digets do not count down but set numbers do. odd odor.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Dec 11, 2008 | Microwave Ovens
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
GE JVM1320 Microwave Oven Logo
98 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
