Question about Samsung Dryers
Samsung dryer gets to one minute mark and displays a circle and the clothes come out cold
  • 4 Answers
There is self diagnosing test you can run. to verify what your machine is trying to say with the circles
Posted on Jun 25, 2014
SOURCE: Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
Posted on Jul 17, 2008
docjohn174
  • 943 Answers
SOURCE: Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Posted on Oct 09, 2008
  • 23 Answers
SOURCE: Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Posted on Jun 19, 2009
  • 7 Answers
SOURCE: burning marks on clothes in dryer
how old is dryer. drive belt may be slipping. Unit may have a faulty control that allows element to superheat. You have a potential fire hazard. What type of clothes are getting the burn marks? Should they be dried in a dryer?
Posted on Jul 02, 2009
Zeevert
  • 373 Answers
SOURCE: The dryer is leaving what looks like brown burn marks on clothes
The marks are coming from your dryer seal. I had the brown mark problem on my Whirlpool LER4634EQ1 Dryer. It turns out that the inner drum seal wore the paint off the pilot diameter on the inner wall. The pilot diameter rusted and the rust transfered onto the seal. The marks on the clothes are rust marks. I replaced the seal on my dryer, but don't know how long it will last. You may need to try and paint the pilot diameter. The seal with glue was $34 delivered from pcappliancerepair.com. Here's pictures of the rust: http://s2.photobucket.com/albums/y48/ZeeVert/Whirlpool%20Dryer/
Posted on Jun 11, 2010
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Samsung frontload gas dryer DV218AG moisture sensor doesn't work properly. Dryer adds minutes to drying cycle even when cloths are completely dry.
Clean the sensors with windex or like cleaner. Farbic soften can build up on the sensors and cause you trouble, Also, the time displayed is an estimate not actual drying time.
Jan 26, 2014 | Samsung Dryers
Dryer shuts off after a few minutes clothes are cold and screen displays ad code
my frigidaire electric frontload dryer runs five in the shuts off what is the problem and where is the reset button i turned off the breaker to the 220 supply but didnt fix it and its only a year old with no warranty please help i have no money to hire a tec right no
Sep 14, 2011 | Frigidaire Electric Dryer
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Burning marks on clothes in dryer
Jul 02, 2009 | Dryers
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
It shows 8.8. and does not start
After having this problem I believe I found a solution. I think the problem is related to tha ambient temperture of the room where the dryer is located. If it's too cold, you get the 8.8 error. When I first had the error it was at 7:00 in the morning trying to dry some clothes that were in the washing machine overnight. I couldn't get the dryer to work and had to go out for a few hours. When I got back around 11:00, the dryer worked fine. The only difference I could think of was that it was warmer than before. So a few weeks later I rememberd this and tried to test my theory. I waited for a very cold morning and tried the dryer and got the 8.8 error. Then I took a small patio table heater and turned it on in front of the dryer for about 20 minutes. The dryer fired up right away. I've used the same routine whenever I get the 8.8 error and it's always solved the problem for me. Hope this helps
Dec 11, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Problem when drying gets to 1 minute mark
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
May 29, 2007 | Maytag Neptune MDE6700A Electric Dryer
Dryers Logo
149 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
