Question about Frigidaire Affinity FAFW3511KW 3.5 Cu. Ft. Front Load Washer - Classic White
The control board on the washing machine
Where is the control board? And what do we do if it keeps beeping saying the door isn't shut when it is and it keeps taking us to the control board but it doesn't say where it is??
4 Suggested Answers
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
  • 6277 Answers
SOURCE: I have a Frigidaire washer model ftf2140fs1, the
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
ercupa190
  • 12223 Answers
SOURCE: Frigidaire FTF2140FS2 front loader-how to tell whether I need to replace the main control board or the motor control board. Machine won't spin,already replaced door lock switch,that's not it.
please see the causes with common sense, before to proceed to exchange some error parts. God bless you
Water Level Control / Pressure Switch
his is the most common reason a washer will agitate but not spin. To check this on most , with no water you should have continuity on pins 7&15. With the tub full 7&16 should have continuity. This video walks you thru checking another type of switch.
Lid Switch
This can be the problem for the washer not spinning . Most whirlpool styles this will effect both agitate and spin but some models will still agitate but not spin.This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to thetransmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise theproblem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Posted on Sep 20, 2012
It says dr and beeps on my frigidaire front load washer
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
I own a maytag neptune washing machine. It was working o.k. and suddenly it won't start. I push the start button and it buzzes and shows a message that says,"It appears the door was not opened...
Hi Debi:
First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.
Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 06, 2011 | Maytag Neptune MAH7500A Front Load Washer
I'm getting flashing error code on washer. It's flashing " DE" Thanks! Sam Singleton
If you've already tried to unplug the machine and that didn't correct the issue, the door latch assembly will need to be ordered and replaced to fix the issue. The latch assembly is just not reading that the dor is shut properly even though it is.
It doesn't matter if it appears to work or not--it's not giving the correct signal to the control board after it locks to tell the control board that the door is latched and shut and ready to start the wash cycle. This is why you need to replace the latch assembly.
Nov 07, 2011 | LG WM2301HW Front Load Washer
F16 showing on display
F16 measn a problem with your door lock.
The machine senses the door is open and will stop. The door lock isn't that expensive and should solve your problem. If that doesn't solve it then you may have a faulty control board.
Try the first choice. Good luck.
Aug 24, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint wm64s indicating door not shut program will not function cus door light flashing...however door iis shut n wont open
You have a mildly confused machine, probably the result of the fact that there is a moment where the door lock can activate, but the sensor that tells if it's shut cant because the door isn't QUITE pushed home hard enough.
First try, just give the door a whack with the heel of your hand in line with where the door catch is. It may be that simple to relocate the door and the sensor properly
Failing that, unplug at the wall and wait 20 minutes. This will, without doubt reset the machine and allow you to open it (While it is still powered off!). Open the door and shut it firmly.... I hesitate to say SLAM the door.... But slam-ish won't hurt, just don't be stupid about it!
All should be OK going forward
Jul 04, 2011 | Hotpoint WMA64 Front Load Washer
Keeps beeping
stuck door switch or mis coommunicating control board
Dec 19, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Washing machine - door problem
it sounds like door mechanisim has fallen off.remove the top of washer/dryer and look down the front to where the door catch shuts and see if there is anything attached to it.if not your have to reconnect it.Let me know and ill give ya more details
Sep 03, 2007 | Hotpoint Ultima WD72 Front Load...
Faulty door which keeps beeping
The door could be closed physically but the not electricity because a defective lid switch that should be replaced. Good luck!
Nov 01, 2006 | Hotpoint WMA76 Front Load Washer
Frigidaire Affinity FAFW3511KW 3.5 Cu. Ft. Front Load Washer - Classic White Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
