Question about youtube.com
Ignition switch for a 1999 ford escort car wont start and have replaced the starter
    New Friend:
Check the battery's water level, post connections, etc. Also, there is a chance it couls=d be your starter solenoid.
Posted on Jan 08, 2013
Mondeo wont start, makes a click sound when ignition is turned on
hi sounds like your starter motor has packed in with all the trying.. just quickly put your car in 5th gear and give it a rock this might release it if not then you gota replace it and as a must get your battery charged up so it has the correct cranking amps to turn the starter
Dec 24, 2009 | 1999 Ford Escort
1994 Ford Escort, will not start. i have replaced the starter, starter relay, and battery. the car still will not start. please help.
hi,
set the parking brake and make sure its in neutral then
try to bypass the ignition switch by jumping the starter relay under the hood. take the small wire off the relay and use a 2 foot piece of wire to go from the positive battery terminal to the terminal on the starter relay you just unplugged. if it turns over and if its a manual transmission the clutch pedal interlock switch may be busted, on the clutch pedal theres a small switch that senses the pedal is to the floor and it wont start. you can try to bypass that with a simple jumper wire. lastly if neither of those do it then you may have to drop the steering column and put a new ignition switch in it.
jm
Dec 15, 2009 | 1998 Ford Escort
I have a problem with my ford escort 1995 it wont start i replase the batery for a new one and i replase tht startmotor but stil wont start can some one help me please
It can only be either the ignition swith or a broken wire between ig switch and starter solenoid, if you take off the plastic bezel around switch I think the starter sol wire is white with red trace,.with a lengh of wire from the pos on battery, touch to starter wire at switch, if it then turns engine over, the fault is switch. If not check other end of starter wire where it connects to starter solenoid on starter
Aug 25, 2009 | 1995 Ford Escort
1999 Ford Escort Won't start after replacing Plugs and cables.
check the battery if its ok, check for power at the starter with a meter or a test light. it sould have a constant power source and one that has power when you turn the key to start. if those are there you need a starter
Apr 17, 2009 | 1999 Ford Escort
WONT START
Thai is either ignition cylinder or starter coil, or a problem with starter motor/wirings to starter motor.
The starter motor must be energized directly (in neutral, and possibly using a remote switch) to check that is working.
If the starter motor is fine, check that there is power coming to starter motor when you ignite.
If there is no power, test power at ignition and eventually replace ignition.
Feb 18, 2009 | 1998 Ford Escort
Wont start
is the earth cable giving a good engine and body contact.does your starter have two terminals and if so are they the right way around?is the battery any good?Is the engine able to be turned over by hand Make sure you have agood 12v supply to the starter solenoid when cranking the engine An engine test probe/light would be of a lot of use for you to do that test
Oct 07, 2008 | 1993 Ford Escort 4 Door
1995 Ford escort fuel pump problems
Correection to location:
Driver’s foot well, behind the kick
panel
Sep 30, 2008 | 1999 Ford Escort
youtube.com Logo
32 people viewed this question
Top youtube.com Computers & Internet Experts
Mike
Jerry King
Jerry King
Are you a youtube.com Computer and Internet Expert? Answer questions, earn points and help others
