Question about Toshiba Office Equipment & Supplies
Toshiba e studio 351c - change color cartridge
  • 46 Answers
SOURCE: Toshiba Studio 351c Call for service
You need to post the error code (top right hand corner of the screen
Posted on Jun 11, 2009
  • 10 Answers
SOURCE: Toshiba e studio 351c need firmaware
It depends what the copier is doing, is it giving error codes
one of the main faults on the copier is it dumps colour toner and that causes problems
need more info
Posted on Jul 02, 2009
Copier_God
  • 57 Answers
SOURCE: toshiba e-studio 280
Go into 'User Functions'
In there somewhere will be an option to replace the toner, press the cyan toner symbol and open and close the front door, the 'enter button' will be able to be pressed.. press enter and you should be ok..
Posted on Oct 16, 2009
  • 10 Answers
SOURCE: Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Posted on Nov 06, 2009
  • 9 Answers
SOURCE: We replace the used toner
There is a sensor just behind the waste toner box that sends beam through the water toner box to see if reaches the other side. If it does not, then the sensor thinks that the box is full. So you need to clean the waste toner box with some liquid cleaner so that it looks white from outside. Once the box is dry, try again. This should work now. Otherwise, there is problem with the sensor.
Posted on Sep 24, 2010
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
Where do you add the developer on the 351c
Developer must be replaced by a technician. Old developer has to removed and new installed. Then there are software adjustments and counters to be reset as well.
Sep 04, 2012 | Toshiba E-studio 351c Color Copier....
I have a toshiba e-Studio 351c show E030 , i was remove the paper jammed but the machine not work and still show E030
clear very well the paper path especially if there is bridge who trasfer the paper to the finisher and check the sensor inside it or check if there is any load at the main motor
Nov 30, 2011 | Toshiba e-Studio 350 Copier
My toshiba copier keeps saying job status change paper type. how do i get it off that? thank you
Your copier is likely trying to print to a different thickness of paper (ie thick 1/thick 2) then you have in whatever tray it is trying to print from. You will either have to change what is in that drawer via user functions or delete the job and try it again with a different paper type.
Sep 07, 2010 | Toshiba E-STUDIO 720 Copier
Toshiba e-studio 280
Oct 08, 2009 | Toshiba E-Studio 3511 Color Copier
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
Had a power outage, not a surge, now reads call for service.
Press "clear" and "8" simultaneously and hold, this should display the error code...what is the error code?
Jun 14, 2009 | Office Equipment & Supplies
need more info
Jun 12, 2009 | Toshiba e-Studio 350 Copier
Printing in Color
what model if is Toshiba e-35 or e-350 all this machine is B & W you only can print in colour with e-3511 or 351C or 2500/3500 machine
Aug 12, 2008 | Toshiba e-Studio 350 Copier
67 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
