Question about Lexmark X75 All-In-One InkJet Printer
Ink cartridge my boyfriend just gave me his lexmark x75 copy/printer. I went to walgreens to get my black ink cartridge refilled but when i placed back in the printer it does not print clearly. I print a word document and it prints with lines over the typing. Would you suggest for me to buy a brand new one to replace it completely? Being that this printer that given to me had not been used for quite some time because it had run out of ink and it had not been used for more than 4 years....
  • 191 Answers
You may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Posted on Feb 06, 2009
How can I make printer recognize refilled cartridge on lexmark prevail pro 705
Refilled cartridges will not reset the ink levels. The printer will still recognize it as empty.
Please be advised that refilled/remanufactured cartridges could damage your printhead and will not be covered under warranty.
Nov 27, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
Apr 11, 2010 | Lexmark X4530 InkJet Printer
After i refill my lexmark cartridges the nossels clog up..
I do not think your nuzzles are "clogged" rather they are blocked with dried ink. and that you can easily resolve if you follow the procedure below. All inks do dry out and block nuzzles especially the black one.
Ink cartridges may be new or old or refilled, but their nuzzles may be blocked; depending on manner of storage and prevailing climatic conditions. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means there is good ink flow at the nuzzle and it is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty or still blocked. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 07, 2009 | Lexmark PrinTrio X75 Printer
Screen kept saying right side ink cartridge missing
If contact missing, then buy another ink cartige. It's probably too old.
Sep 05, 2009 | Lexmark X75 All-In-One InkJet Printer
Refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
Refilled cartridges
Walgreens had gave me the wrong print cartridges back. They had my info on them but they belong to a HP printer instead of a Lexmark. We took them back and had to go thru a lot to get them straighten out. My cartridges were nowhere to be found so I'm sure the HP customer will be looking for their cartridges also. From now on no more refilled cartridges for me. Lexmark only! Thanks for the help.
Aug 14, 2008 | Lexmark Office Equipment & Supplies
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
Which black cartridge does this need?
Yes you can refill the cartridges. Also Walgreen's refill cartridges now. $10. for black and $15. for colr cartridge refills. I've been using their refills and they work fine. It's less mess that doing it myself. And they use good quality ink... But you can refill them.They also carry universal refill kits at walgreen also. Also the cartridges are not hard to find you can order them at several places online. Google x1240 for sites. Also Staples sell the cartridges.
Sep 25, 2007 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
