Question about Kenmore Elite HE4 Electric Dryer
Kenmore dryer error
I just bought a Kenmore HE5 dryer. It dosen't work! When I turned it on, I recieved error code F:70. What does this mean?
  • skipjackson Dec 24, 2008
    we have an HE5 ,less than a month old; today we received an error code F70?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
I opened the unit and replaced a 1.25A fuse which had blown. check your wiring diagram. look in back panel and check the little fuses but this is the one you need to replace. 1.25a thats the main cause of this error
Posted on Jul 30, 2007
Based on my brief internet research on this issue, after recieving the same error code, it appears to result from a communication issue between the electronic systems of the machine. Personally, I'm returning mine. Too many posts about this error.
SOURCE:
A code E1 flashes the dryer shuts off and the clothes are still wet
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 25, 2010 | Kenmore HE5
Error F13 on Kenmore dryer He5
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 17, 2010 | Kenmore HE5 Electric Dryer
I got a f25 code on my he5 Kenmore washer . What is wrong?
This is a communication error with the motor. The first spot I would check the MCU on the lower front of the unit. Remove the lower front panel three screws check the wires there unplug and plug back in if that does not work check the wires on the top board. The top has three screws in it then it will slide back and off.
Apr 26, 2010 | Kenmore HE5
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
267 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
