Question about Electrical Supplies
I have a titan 7500 diesel ,electric start generator the battery does not seem to be recharging while the generator is running . What is the problem?
4 Suggested Answers
  • 18 Answers
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Posted on Sep 19, 2008
protek480
  • 1714 Answers
SOURCE: generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
Posted on Jun 26, 2009
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
7500 titan diesel gen. About 4 hrs. Into run. It will trip to stop an shut down. Not low oil. Then flip it back to run an it will crank back up an run another 4-5 hours. What is doing this.
it could be a flow sensor in the fuel line to stop the engine before air gets sucked in form low fuel or broken lines
I would first go to the tank vent and ensure that it is not blocked , restricting fuel flow to the pump
there is nothing obvious as the engine would not restart so look for the simple things that trip the stop system
if there is any electronic control , it may be a slowly overheating component that needs checking but I would leave that to a last thing to check
Oct 19, 2015 | Diesel Electrical Supplies
Home generator wont start
Check for spark. If it has spark, try starting using starting fluid. If that starts it, then you know it is a fuel problem. You may need to rebuild the carb.
Aug 10, 2014 | Coleman Electrical Supplies
My 7500 watt generator doesn't produce any power
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Jul 31, 2014 | Honeywell 7500 Watt Generator 15 HP Engine...
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
The battery won't start the generator. It has to be hand pulled to start. how do I recharge the battery?
Sometimes it is more expensive to fix the problem with the generator charging system than purchase a small 12v battery charger. I would purchase a 12v small battery charger (5A) that you can keep plugged into your house hold power. This will maintain the battery at full charge so it is ready to start when you need it.
Jan 29, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
Diesel generator does not working
After using a diesel generator for a long time, some malfunctions may occur that will cause the generator fail to start.
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
1. Air in the fuel system
2. Fuel line obstruction
3. Fuel filter clogging
4. The handle position of fuel injection pump is not correct
5. Battery power shortage
6. Run out of fuel
Learn more reasons from this article.
Why Diesel Generator Fail to Start
Feb 22, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Sep 18, 2008 | Electrical Supplies
Electrical Supplies Logo
237 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
