Question about DeLonghi Ovens
My oven is not heating up the fan is working and element is only months old
Element has been replace about 2 month ago,fan working but not heating up
  • 249 Answers
SOURCE: neff u1721fan oven element has been replaced 3 times in two months
is it the right voltage?is the new element screwed tight when fitted?they should last alot longer than that--Ire close bye.
Posted on Nov 28, 2007
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
apart4u
  • 213 Answers
SOURCE: My fan oven element( Neff U1452 )has been replaced
they should last 12 months minimum there could be a problem with your fan motor here is a standard fan oven check list.
You-Tube video "6QGurNvbI0Q" placeholder (do not delete)
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 14, 2010
SOURCE: Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Posted on May 10, 2010
2coolrick
  • 560 Answers
SOURCE: Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Posted on Jun 05, 2010
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2011 | Smeg Ovens
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
Jan 13, 2010 | Neff U1452 Double circotherm plus Electric...
Candy double oven purchased 14 months ago. Bottom oven cut out during cooking. Fan and light works no temerature though
It's most likely to be the oven heating element that is 'gone'. You will need to have it replaced.
Jan 08, 2010 | Ovens
Single oven BT2385SS - took 2 hours to get to temperature after blowing a RCD circuit in the fuse board. Fear that element has gone at 2 yrs and 3 months old.
I think your fear is correct, it sounds as if the heating element is going although you do not say if the fan is working.
Dec 31, 2009 | Baumatic Ovens
Whirlpool 6MFOS oven not heating
Do you still have this oven? I broke my glass door and need a replacement. thanks
Oct 19, 2009 | Whirlpool Ovens
Fan works but oven doesn't heat
Check at the terminals and look for burned wiring
Sep 24, 2009 | Ovens
Ovens Logo
21 people viewed this question
Top DeLonghi Ovens Experts
Naftali Haskell
Level 1 Expert
Mike Teter
Jon Lamb
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
