Question about Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module
Ford Bi Directional Remote Start
I only get feedback on my Fob 50% of the time. It is not a range issue as I am only 20 feet away from the car. The car usually starts, jsut don't get feedback to the fob. System was installed by Ford Dealership on a 2007 Fusion. Sometimes I get 2 blips on the red LED, but none on the green LED. The antenna was mounted on the back of the electronic rearview mirror by the dealership.
Hi there, I know someone who had the same problem, and it turns out that the keyfob battery was a little low for some reason straight out of the box.  They tried replacing the battery and it works much better now.  Hope it works that way for you too!
Posted on Jan 27, 2009
How do i start the TGB 125 i hav a key and a fob but dont know where to point the fob
You can stand 20 feet away from the vehicle and point the fob at the vehicle and it will work, IF the fob has a good battery and is the right one for the vehicle.
Nov 11, 2017 | Cars & Trucks
Theft lock engaged because multiple attempts to start without key in car. How do I reset?
Try locking it with the fob, then unlock it with fob. If the antitheft is engaged, the light will stay on or flash.
Oct 02, 2016 | 2010 Land Rover Range Rover
Changed battery in keyless remote and now doesn't start car or open doors
  • HOW TO - Change the battery and quick fix your car remote ...
    ? 9:32
    Sep 1, 2011 - Uploaded by tyreeztt
    Also if your remote isn't working with a new battery please check out this ... TO - Change the battery and quick fix your car remote / keyless entry ...
    Remote Key does not lock / unlock doors after battery change ...
    Apr 17, 2010 - After I changed the battery, it would no longer lock / unlock the doors. ... I can start the call and all .. its just the door and trunk lock / unlock function that does not seem to work . ... now your fob is learned... the keyless entry goes into a "sleep" mode to preserve the batt.. if u do not use the ... Still don't work .
    how do i reprogram my lock remote to my car? i changed my ... > Questions > Hyundai > Tiburon
    CarGurusAug 17, 2009 - i change my battery an now my lock an un lock buttons dont work on my remote how o i reprogram it? ... I have a Hyundai 2003 Tiburon, and the followingworked for me, get ... However for a replacement keyless remote fob, you will have to go to ... And no, they don't do it for free (ranges from $30-$50 in my ...
    Top 5 Tips in Fixing a Keyless Remote ' eBay > ... > Safety & Security > Keyless Entry Remote / Fob
    Key fobs that don't permit entry can be a major hassle for drivers, but fortunately, there... Drivers with a bit of basic electronics experience are often able to replace their ...After confirming that a remote is faulty, try replacing its battery. ... like "Jeep Wranglerkeyless remote," to find listings that will work with specific vehicles.
Jan 26, 2016 | 2005 Ford Freestyle
2003 malibu alarm won't stop
Well when you replaced the battery did anything else on the key fob work? Often times you have to reprogram the remote in order for it to function properly. Try getting inside the vehicle and manually lock all doors with the driver's side switch. Put the master key in the ignition switch and turn the switch to the run position but do not start it. Now push and hold the lock and unlock buttons at the same time until the locks make noise....may take 10 to 30 seconds. After you have the key fob programmed, see if the alarm will turn off with the remote. Did it work? The only way to totally turn off the alarm is with a GM Tech @ or 3 scan tool and go into body control bidirectional controlling procedures or with a very good aftermarket scanner with good bi-directional functionality.
The alarm works via the body control module on this vehicle and i am thinking it uses the PK2 system and if you do not have a properly coded key or the BCM is loosing memory, then check for any and every blown fuse and replace as start with.. If the vehicle stays running after starting then the bcm/key is reading correctly.
Jan 21, 2018 | 2003 Chevrolet Malibu
08 chevy impala remote start fob range
any further than 20 feet and you have the car started and running is an open invitation for people to steal your car before you get to it
however you can spend time on the net looking for a site that sells more powerful remotes
Oct 30, 2017 | 2008 Chevrolet Impala LT
Are bi-directional remote star ts ok im thinking off putting it on my vehichle I heard bad things about it
This depends on the brand you are installing. I didn;t like them at first but a 2 way system is way better. It actually lets you know what is going on with your vehicle. I would recomment Auto Start TS-2471 easy to install and program and they work very well with few problems.
Aug 09, 2010 | Directed Electronics 1100f Ford Pats...
I have a BJC80 printern with a scanner head. My pc is an xp opertins system. It is connect to parallel port but when i try to scan, it sends me back an error message saying there is no communication.
One of two issues may be involved. 1) Make sure you have a bi-directional IEEE-1284 parallel printer cable, 6 feet or less long. 2) Make sure that the parallel port is set to ECP mode (the BIOS is accessed by hitting F1 or F2 during boot on many computer, check your manual.) Try a new cable (just in case the cable has just enough damage to prevent the scanner from getting the full bi-directional communication).
I hope this helps.
(the lack of bi-directional communication only disables the scanner, the printer will still work)
May 08, 2010 | Canon BJC 80 InkJet Printer
Remote start will work intermittently. have tried from 10 feet to 50 feet with same results. won't start. went to dealer they stated its because the range is not too high for the factory installed system....
Have you changed the battery in the remote?
Do so, then re-introduce the remote to the remote start system following the manufacturer's instructions, and the problem should be solved.
Dec 26, 2009 | Toyota Camry Cars & Trucks
2006 Chevy Impala Remote Start Poor Range
Yes some do some don't, my 2005 Dodge 200-400 feet, my 1996 Corvette 20 feet, my wife's 1998 Buick about 50 feet, is the remote battery ok? should be changed at least once a year
Dec 03, 2008 | 2008 Chevrolet Impala
Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module Logo
783 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
