Question about Pyle NEW 2011 PYRAMID PB3818 5000W 5000 Watt 2CH 2 Channel Car Amplifier Amp
PYRAMID PB3818 5000W 5000 Watt 2CH 2 Channel Car Amplifier Amp cuts out after 10mins
How much rms is the pyramid pb3818 5000w amp ?
Posted on Feb 06, 2014
2 Suggested Answers
SOURCE: car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Posted on Feb 09, 2009
B channel cuts off after a few minutes
Speaker is blown or amp channel is. Swap channel connections from a to b, etc, and test channel again. If it doesn't clip you have your answer. If it still clips out, your amp has a blown channel.
Apr 20, 2014 | Pyramid Zpa150 1500-watt Professional...
I have a boss rt645 2ch 1400 watt amp would this amp properly push a pair of 12 inch mtx terminators.
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Mar 04, 2011 | Boss AUDIO RT-645 2-Channel Riot Series...
Bought a car and this amp was in it(Pyramid Crystal PB781X 2ch MOSFET). it is missing the fuse. what fuse does it require?
25 to 30 amp fuses are the most commonly used fuses in any amp and since yours is a 1000w amp, I would use the 30a.
Sep 05, 2010 | Pyramid 2CH 1000W CRYSTAL AMP Car Audio...
What does it mean when the red IND PROTECT light is on? my subs cut in and out, mostly out with the occasional hard hit popping up in the middle of a song. Whats wrong?
You've got the gain to high and the amplifier is clipping the sound frequency causing it to distort. Possible problems are you have a bad speaker(s) and the reading is below 4 ohms. Each of the 4 channels can only take 4ohms. If your bridging 2 speakers to this amp you have to also make sure you are only bridging 4ohms anything lower will cause the amp to overheat. Dont put 2 speakers in parallel on one channel or you will definitely have more problems.
Apr 07, 2010 | Pyramid 1000 Watt 4 Channel MOSFET...
How much does this amp run
Well here is the stats
2000watts 2-channel
Output Powers
• 500W (RMS) x 2CH (2 Ohm) 500rms each channel
• 600 (RMS) x 2CH (4 Ohm) 300rms each channel
• 1000W (RMS) x 1CH (4 Ohm)
If your talking about price it runs about...
$100-130
Jan 12, 2010 | Solid Audio Formula Series F2000 2-Channel...
1600 watt pyramid royal blue 2 channel amp need diagram of amp itself
if i keeps blowing fuses then it means the amp is bad
May 12, 2009 | Car Audio & Video
Pb1281x pyramid crystal 2ch mosfet amplifier 1600w what size fuze i got a 20amp in it it blows when i got it terned up
Hello sunshanel,
You did not say what you have the amp connected to and what the impedance load is. It is only stable at 4 ohms and if a lower impedance is connected, say 2 subs in parallel, it would try to produce more power when you turn it up and would most likely blow the fuse. 20 amp sounds right for the amp. The power rating of 800 watts per channel is peak power, not RMS, and many low-end manufacturers tend to state bigger numbers in the ratings.
Hope this helps.
Apr 26, 2009 | Pyramid PB1281X Car Audio Amplifier
Amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
Mar 22, 2009 | Pyramid PB736GX Car Audio Amplifier
Pyle NEW 2011 PYRAMID PB3818 5000W 5000 Watt 2CH 2 Channel Car Amplifier Amp Logo
143 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
