Question about Dell p713w AllInOne InkJet Printer
Dell 713w print blank paper
It can copy fine but print blank
4 Suggested Answers
SOURCE: Dell 942 all-in-one inkjet copies have faded edge
The issue you have posted could be related to number of reasons, In order to fix this issue please try the steps given below.
1. Check if the paper size using is the one recommended or suitable with the printer.
2. Check if the document that you are placing on the scanner bed to copy is placed accordingly.
3. Check if there is a size or resolution which is set in printer preferences and it matches the paper size that you are using while scanning.
4. You can also try resetting the printer to factory defaults if you have started experiencing this issue recently, in order to reset the printer to factory defaults all you need to do is to power off the printer disconnect the power cord to the printer, then press the power button for about 10 to 15 seconds and the reconnect the power cord and power on the printer, once the printer is powered on press the power and the menu buttons at the same time and hold them for about 15 to 20 seconds the printer will turn off automatically.
5. You can also update the printer firmware for the Dell’s support site which is support.dell.com
Note while updating the printer firmware make sure that your printer and compute does not power off or restart.
Should you require any further assistance regarding the printer or even require assistance regarding any other computer related issue in future please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Posted on Jan 31, 2008
don_farr
  • 1011 Answers
SOURCE: Dell all in one 946 printer
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 20, 2010
Joed911
  • 4338 Answers
SOURCE: Paper jammed in Dell 713W
There is a Paper empty sensor (black paddle) on the right side. It is about 1/4 of from the right edge of the paper. It senses the paper and it gets toggled when the paper goes through. Sometime the paddle comes loose or breaks. from a previous paper jam. Look at it with a flashlight..push it back and it should toggle the switch and retun to it proper position.
Posted on May 28, 2011
My Dell 3115cn MFP prints 3 blank pages between prints or copies if I print more than 1 copy how do I fix this? What is causing it?
I will do first a full printer cleaning, that mean take off all dust and anything can that can be inside the printer (ex.bugs and dirt accumulation).
Second try to locate the printer rollers and check if they are in good condition.Printer rollers need to be in good condition because those are the parts that move the paper inside the printer.
Also when you feed the papers into the feeder make sure you air the paper so they don,t stick together.
May 07, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
My printer prints blank pages
do you have to copies of the same printer in control panels printer menu? dell printer
Nov 30, 2011 | Dell 926 All-In-One InkJet Printer
Paper jammed in Dell 713W printer, removed paper and now will not print, paper gets pulled up to roller but no further
May 28, 2011 | Dell p713w AllInOne InkJet Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
My Dell Printer skips lines when printing
mine did the same i used copy paper now i use ink jet and it works fine
Oct 06, 2008 | Epson Stylus C86 InkJet Printer
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Will Print, Won't Copy
Make sure the drivers have been loaded properly by uninstalling them and completely installing them again restarting the computer and printer several times.
Aug 01, 2007 | Dell 924 All-in-One InkJet Printer
Dell p713w AllInOne InkJet Printer Logo
14 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
